Need help - strange sound from my 650R
11 replies to this topic
  • Mudshark
Posted February 15, 2006 - 06:37 PM
I have a new '06 650R and it makes a Jingling / clinking sound, kinda like
a small bell when I just tickle the gas to keep it rolling along. It goes away
if I roll off the gas or bang it open...... anyone know what it could be??
I pulled the shrouds, seat and tank but cant find anything lose.
I don't want to wait for it to one day stop and then look for whats missing :thumbsup:
  • snaggleXR650
Posted February 15, 2006 - 07:01 PM
Hard telling. The valves can be kinda clanky sometimes, be sure and check them during break in anyway. Otherwise, it could be almost anything. Does it do it if you rev it sitting still (in neutral), or just when the bike is in motion?
  • creeky
Posted February 15, 2006 - 07:09 PM
???drive chain/sprocket???
  • Mudshark
Posted February 15, 2006 - 07:30 PM
No... not yet. only while in motion so far. if it would do that I could locate it...
I thought it could be, because the CS has quite a bit of play in it (in and out
play) that would cause the CS sproket to float and maybe jingle wile not under
load... but I hear that the play is normal, so you all should hear it too ?
Thanks for the input so far though... this is driving me cazy, I keep expecting
something to fall off :thumbsup:
  • snaggleXR650
Posted February 16, 2006 - 05:16 AM
It has to have something to do with the drive system then. If you have been messing around with the front sprocket, make sure you have it mounted with the boss sticking out, otherwise the chain will ride close to the vertical frame member and scape it up. If you have a good solid stand, get the bike up off both wheels while its running. Pop it in gear and keep your hand ready on the clutch. Listen around while the rear wheel is spinning.
  • Mudshark
Posted February 16, 2006 - 06:14 AM
Great idea, thanks Snaggle, I have a motojack I'll run it on it tonight.
BTW the sprocket was mounted by the dealer... it could be wrong :thumbsup:
  • Old_Man_Time
Posted February 16, 2006 - 11:57 AM
Do you have aluminum bark busters on the bike? If so check to make sure your manual decompressor lever is not touching the bark buster. It makes the sound you are describing and it sounds like it is coming from the engine. :thumbsup:
When it's making this sound just place your finger lightly on the decompressor lever. If the noise stops your peace of mind will be restored.
  • soccermania688
Posted February 16, 2006 - 12:24 PM
on the front sprocket there is a flat side and a side with a part sticking out near the center hole which side faces in, just wondering?
  • AdamW
Posted February 16, 2006 - 02:39 PM
My near new XR had some jingling. Turned out to be the shift lever was on very loose. No probs now. It would rattle with certain RPM's.
  • pigryder
Posted February 16, 2006 - 05:56 PM
dude Ive had my clutch lever and my skid plate make the same kinda noises!!
  • Max Power
Posted February 16, 2006 - 06:51 PM
Put a loud pipe on and you will fix the problem/s. :thumbsup:
  • Mudshark
Posted February 16, 2006 - 08:35 PM
The side with the part sticking out should face out, away from the motor.
