Just finished dressing up the 06 450
27 replies to this topic
  • yamajoe
Posted February 12, 2006 - 11:19 AM
Well I finally got my 450 the way i want it...Renthal sprockets and gold o-ring chain, seal savers, steel oil filter, devol skid plate and radiator guards, renthal hand grips and dough-nuts, pro-moto billet endcap, dunlop d756 front tire, frame mounted hour meter, re-routed the breather tube to the airbox, raised the forks in the triple clamps, 48 pilot and zip tye fuel screw. I will post pics soon!
  • mitocross
Posted February 12, 2006 - 01:11 PM
pictures please
  • Stevequest2000
Posted February 12, 2006 - 06:13 PM
How is the fit for the Devol rad braces. I have only been able to see pics that don't go into that much detail. Do they appear to be strong as the Works Connections? The Devol is the only manufacturer for the '06 that I can find so far unless you know of any others. Thanks
  • yamajoe
Posted February 12, 2006 - 07:31 PM
the devol ones fit nice and look even better, in my opinion the coolest looking ones I've seen in a while. I will post pics asap I promise, i want to show it off it's a damn shame that beautiful bike sitting in the garage with nobody to look at it :thumbsup:
p.s. Devol also claim's that along with better protection they also have better air-flow!
  • mxmob33
Posted February 12, 2006 - 08:10 PM
Anyone use one of the K&N air filters yet? They sure look cool (no cage, no backfire screen), like putting a muscle car air filter into your dirt bike. Supposed to have much better flow, haven't heard any first hand reports yet though.
  • mtrdrms
Posted February 13, 2006 - 05:24 AM
My Devols are on order, cant wait to see those pics! :thumbsup:
  • 450_rider
Posted February 13, 2006 - 09:39 AM
I have been using a K&N for a while, its the only filter i have used other than the stock one and its really no fair comparison, it flows extremely well. But that is on my 03 but i doubt there is a difference between 03 and 06 using one. This thing hauls you and almost hear the air coming into your engine; if you ride in sandy areas there is the possibility of fine dust getting through and hurting your valves.
  • Drfletcherdc
Posted February 13, 2006 - 10:24 AM
Which sprocket did you get? I just got my blue Renthal (50T) in on Friday and put it on with a gold RK chain. Looks sweet!
  • yamajoe
Posted February 13, 2006 - 07:05 PM
black renthal 49 tooth
  • kizzle426
Posted February 13, 2006 - 07:16 PM
Any pictures yet? I'm dying here.
  • N_Boyd
Posted February 14, 2006 - 09:55 AM
come on where's the pics???
  • Drfletcherdc
Posted February 14, 2006 - 03:57 PM
I don't know how to. Any help on posting pics would be appreciated.
  • Satch0922
Posted February 14, 2006 - 04:50 PM
we must have visual proof for any post titled "Just Finished Dressing up the 06 450" :thumbsup:
You can get a free account at www.photobucket.com . Upload your pictures there and then post the link to them here on TT ! It's easy! :thumbsup:
  • 2012 450 xc-w
Posted February 14, 2006 - 05:22 PM
I bought some Devol rad gaurds and sent th :thumbsup: em back fit was crappy and made the bike at least 1" wider at the radiator tanks on both sides.
  • PK
Posted February 14, 2006 - 06:08 PM
K&N's flow more air, that is true, but only because the filtering media isn't a fine as a normal foam air filter. If your worried about running it in a dusty environment, maybe you should re-evaluate your choice of filters as any kind of dirt, no matter how fine it is, that gets past the air filter really accelrates the valve wear.
Now, where are those pics? I'm curious to see the Devol radiator guards. I guess it's like everything else from air filters to radiator guards, some like them, some don't...
  • Drfletcherdc
Posted February 15, 2006 - 10:51 AM
Here's my dressed up 06 450F.
- Front oversized Braking
- Rear Braking
- Ride Engineering Front Brake Clamp
- Ride Engineering Timing Caps and Oil Fill Plug - Blue
- ASV levers
- Renthal Fat Bar RC high bend
- Scotts Steering Stabilizer
- Renthal 50t Blue Sprocket
- RK racing chain
- Works Connection Front and Rear Resevoir caps
- Uni Air Filter
- Ride Engineering Rear Axel Blocks
- Ride Engineering Front Wheel spacers
- Over sized Titanium Factory Footpegs
Coming Soon....
Skid Plate, Rad braces, Race Tech Suspension
  • Drfletcherdc
Posted February 15, 2006 - 11:40 AM
You can get a free account at www.photobucket.com . Upload your pictures there and then post the link to them here on TT ! It's easy! :bonk:
Thanks for pointing me in the right direction. It was too difficult for someone as computer challenged as myself. :thumbsup:
  • cowboyona426
Posted February 15, 2006 - 11:59 AM
Looking pretty good so far! :thumbsup:
  • SureBlue
Posted February 15, 2006 - 01:03 PM
My visual proof
- Greased steering, swingarm, linkage and bearings.
- Spike tires and thick tubes.
- Renthal 14-tooth front sprocket and DID 520 ERT-2 Gold chain - stock rear sprocket.
- Reed/Henry ProTaper with Cycra handguards, Thumbsavers and Barsavers.
- PC Racing ProSeal airfilter seal, TwinAir filter.
- Rerouted breather tube into airbox.
- 48 pilot and 175 main, fuel screw 1,75 turns out (-8 degrees Celsius at sea level).
Still to come: Hinson basket, yellow sealsavers, TMdesingnworks Factory Edition Blue Kit (guide, slider and roller), ZipTy fuel screw and magnetic drain plug, Scotts stainless steel oil filter.
Cheers
  • PK
Posted February 15, 2006 - 01:56 PM
Sure Blue, kind of weird to tear apart a brand new bike but it's the best time to do it. I was wondering how much grease was on the bearings from the factory? Also, why did you use the 175 main when most are using the 170 main? I'm just curious if you have had any experiences that caused you to use it rather than the smaller 170. Are the ProSeal air filter seal the magnetic drain plug the same as the 03-05's or is it specific to the 06's? One other thing is I used the TM design slider on my 03 450 and it made so much noise, I took it off and use automotive goop with some coarse foam under the stock slider to prevent the chaffing. I had used them previously with great luck but I think when they changed the design to where you could install it without pulling the swingarm, I think it made it no better than the stock one since it moves around more than the prior design.
Doc Fletcher, can a chiropractor do work on himself? You must be in demand at the track. The bike is looking good, no unnecessary bling to make it look excessively bling'd, very tasteful application of the bling.
  • 0 replies
  • Hot  30 replies
  • 3 replies
  • Hot  28 replies
