Complete teardown. Any suggestions?
11 replies to this topic
  • Wheels up
Posted February 12, 2006 - 08:00 AM
2004 XR 650 L
I am currently doing a complete teardown of my motor to fix a tranny problem. We have to split the cases so it's a major job.
Anyway, the bike already has a hotcam...but the rest of the motor is stock.
What should I upgrade while it's apart??
Clutch, piston, rod, etc etc????
Mike
  • mgs781
Posted February 12, 2006 - 09:06 AM
2004 XR 650 L
Mike
Tranny problem on a 2004, sounds like abuse to me. :thumbsup:
Replace the first gear with one from an XR600R, much shorter, some magazine did a write up on it not too long ago.
You can do a piston, weisco or other, they are pretty much all the same. Port the head and do a three angle valve job. If it were me, I would do the 715cc kit from L.A. Sleeve, but you'll have to get the cases bored to accept the oversized sleeve.
Not much else to do other than replace things that shouldn't be worn yet.
MGS
  • GrayGhost
Posted February 12, 2006 - 06:29 PM
What tranny problems have you encountered?
  • wr450fyamaha
Posted February 12, 2006 - 08:12 PM
MGS
that or a defect....I would throw a new piston in it and have the ports and valves done....bore it out a little.
  • goblin127
Posted February 12, 2006 - 08:17 PM
Yea I'd like to hear about this also. :thumbsup:
  • Wheels up
Posted February 13, 2006 - 04:22 AM
Tranny wont shift. Shifter will move up and down while motor is running but it wont change gears.
  • XR650L_Dave
Posted February 13, 2006 - 08:48 AM
You could put the kicker back on.
D
  • sorenlaf
Posted February 13, 2006 - 10:16 AM
I'm new to the XR world, so I may be off-base here, but on some other bikes I've owned, this might be a problem with the shift linkage inside the right hand case cover.
There's usually a widgit that grabs (and rotates) the end of the shift drum, and I've seen problems there.
Just a thought, and you can probably check it w/o pulling the engine.
--Soren
  • Wheels up
Posted February 13, 2006 - 10:26 AM
The motor is out and all tore apart now. We are searching for the culprit.
  • Boy Honda
Posted February 13, 2006 - 11:45 AM
It sounds like a bent shift fork.
  • rmhrc630
Posted February 13, 2006 - 12:54 PM
I agree - bent shift fork
  • Wheels up
Posted February 13, 2006 - 01:52 PM
I hope it's a bent fork.
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 3 replies
  • 9 replies
  • Hot  60 replies
