426 starting issues
9 replies to this topic
  • calvin71
Posted February 11, 2006 - 01:25 PM
I Have A 2000 yzf and i really need help on how to start this damm thing. i had it out two weeks ago, but it seems that i have to have someone in my bike party to help me start it. Anyone know what the hell is the right combo on getting this going myself????? :thumbsup:
  • Fizz
Posted February 11, 2006 - 01:36 PM
"all you need is love" .. :thumbsup:
the starting routine is this;
#1: push the kick down until you cant anymore.
#2: pull the decomp. handle,
#3: push the kick past TDC as little as possible, (½ inch)
#4: release the decomp. and pull the kick to the top
#5: put your entire weight on the kick ....
i´m pretty light, about 140 lbs, and when my bike is cold i need something to lean the bike on (a tree, a garage etc.) so i can stand up and kick .. when the bike is hot i easily start sitting pretty far back and kicking
  • calvin71
Posted February 11, 2006 - 01:43 PM
Dont I tried starting this thing all morning and all i got was a sore foot even with the boots on :thumbsup: want to sound like a big idiot whats the tcd? :thumbsup:
  • calvin71
Posted February 11, 2006 - 01:45 PM
Can you please tell me wht the tdc is? sorry for the the last messg. messed it up a bit.
  • gunship426
Posted February 11, 2006 - 01:47 PM
top dead center on the piston.
  • Fizz
Posted February 11, 2006 - 01:49 PM
oh, sorry for the technical mumbo jumbo :thumbsup:, TDC is "top dead center" ...
edit: to late. :thumbsup: :bonk:
  • calvin71
Posted February 11, 2006 - 01:50 PM
Thanks so much. If This Works I'll Come And Mow Your Law And Paint Your House!!! :thumbsup:
  • david857
Posted February 11, 2006 - 05:33 PM
First things first bro you need to check you fuel mix screw on the bottom of the carb. After that I recommed taking it out 1 and 3/4 and adjust from there. As for the starting issue try running one stage hotter plug in the bike. If it is a NGK CR8E run a CR7E. I have a 01 426 and it works great for me. Secondly when you pull in your decompression lever and set it to top dead center it is only actually about 2 to 3 inches! I was told in the past to go like half way down of more threw the kick but I found just barely pushing it puts the motor at top dead center and saves me a lot of head ache.
Last but not least check your plug cap and make sure it isn't corroded at all. Good luck man.
  • calvin71
Posted February 11, 2006 - 05:54 PM
Thanks for all the help you guys are great!!! You Are A GOD! :thumbsup: Well i Guess I'm Gunna Have To Come Over A Do So Chores. I Went Out To My Bike And Did What You Said, The !/2 inch Thing And Damm It All To Hell It Started First Kick. I Guess I'll Keep The Bike For A While Longer And Dont HAve To HAve My Friend Start It For Me.THanks Again And I'm Gunna CHange Plugs. :thumbsup:
  • Satch0922
Posted February 11, 2006 - 06:16 PM
Click this
Starting the YZF
  • 9 replies
  • Hot  113 replies
Motocross
  • Hot  491 replies
