Trouble removing bolt on flywheel
5 replies to this topic
  • blazen
Posted February 10, 2006 - 02:45 PM
I'm trying to remove rotor so I can replace my timing chain. I have an E-line ignition on my 426. I'm using an impact driver but the nut will not loosen. Is it reverse thread?
Posted February 10, 2006 - 03:41 PM
No, it's a right hand thread. If you don't have a flywheel holder or an air impact wrench, put the bike in 4th or 5th gear and put a 1x2 board or a hammer handle across the swing arm, as close to the rim as possible, then remove the nut with a socket and a long ratchet or driver. Check the torque in your manual, I believe it's something like 40 ft pounds.
You have a flywheel puller, right?
  • blazen
Posted February 10, 2006 - 04:25 PM
The engine is off the bike and I dont have an air impact driver or fly wheel puller. How much is a flywheel puller? And I guess I will have to find an air impact driver. Thanks for the help-alex
  • KX250FJP
Posted February 10, 2006 - 04:35 PM
I have a KX250F and I used an auto oil filter wrench to hold the flywheel while I turned the nut. I wrapped duct tape around the flywheel so I wouldn't scratch it. I did buy a flywheel puller, it's about the only way to safely get the flywheel off the crankshaft.
The puller cost about $20.00.
  • RideRaceLive123
Posted February 10, 2006 - 05:58 PM
Just don't be stupid like me and use a impact wrench to tighten the flywheel nut and mess up the threads.But I was able to fix them with a tap and die set.
Posted February 10, 2006 - 09:31 PM
Flywheel pullers are about $10-$15 almost everywhere.
Motocross
  • Hot  491 replies
  • Hot  113 replies
