Dumb question about grips
11 replies to this topic
  • wildchubby
Posted February 09, 2006 - 07:48 PM
Ok I admit its been way to long since Ive changed grips on a bike. Whats the best way to cover up this gap. The stock throttle tube has a lip where the oem grip had a matching grove to slip into. The aftermarket grip does not have this groove. Any good tricks to clean this up?
http://i46.photobuck...chubby/grip.jpg
Thanks,
W
  • wr450fyamaha
Posted February 09, 2006 - 07:51 PM
not something i would worry about.....dont know what u could do.....maybe wrap a very thin strip of electrical tape and wrap it around the white plastic....just cover that.
  • goblin127
Posted February 09, 2006 - 09:17 PM
If the groove is small it wont be a problem. I have had good luck putting grips on with hair spray, It slides right on and then after it dries I cant budge them. I still run safty wire around them though.
  • bork
Posted February 09, 2006 - 09:25 PM
Thanks,
W
I saw somewhere to use laquer paint spray & will lube then dry grips on . I still safty wired in two places & still grips are walking to barkbusters . :thumbsup:
  • TeaOneAndOnly
Posted February 09, 2006 - 10:12 PM
actually that is as far as the grip goes. The grips not holding it back there is actually a plastic piece on the throttle tube holding back. You might want to loosen the whole throttle assemble and movie it to the right like 2 cm. Its hard to explain by typing sorry.
  • wildchubby
Posted February 09, 2006 - 10:58 PM
The grip is very solid on the throttle tube. The main problem I see is that Ive got about 3/4" of unseated grip at the bar end. If I was to put hand guards on the bike all that grip would be wadded up and look like a POS? Any other ideas?
  • brichter
Posted February 09, 2006 - 11:39 PM
Just don't do a lot of riding in the rain, or the hairspray will lose it's grip.
Whatever happened to grip cement? That's what I use.
  • thatsgonnaleaveamark
Posted February 10, 2006 - 12:39 AM
you file down the lip flush with throttle tube,buy a nylon washer that fits over throttle tube, and then install grip.washer gives you 1/16 clearance, and deletes the gap. i use renthal grip glue on first inch of bar, or throttle tube, then work grip on.then i take a new razor blade, and cut out the very ends of the grips, enuff to install barkbuster bolts. i have got it down to a science, enuff that almost everyone i ride with has me do theirs also. taking my time, i can change a set complete in 1/2 hour. hope that helps a little.
  • Fordskin
Posted February 10, 2006 - 03:35 AM
All i did was cut off the flanged bit with a sharp knife. It cuts easy. I had to also cut a hole in the end of my new grips and slide them more towards the center of the bars to accomadate the ends of the barkbusters. Dont worry just shave off the flanged bit and push it further on. :thumbsup:
  • wildchubby
Posted February 10, 2006 - 05:00 AM
Thanks for the tips. I'll try shaving off the plastic flange later today.
  • bork
Posted February 10, 2006 - 05:14 AM
I'll let you do mine . Do you use compressed air to blow em on ? I suppose I need to invest in some renthal grip glue.
  • goblin127
Posted February 10, 2006 - 06:53 AM
Find some hair spray it's what a lot of people have used for years. Then safty wire them.
