Removing the air injection pump.
2 replies to this topic
  • ram1000
Posted February 07, 2006 - 08:09 PM
How do I remove pump or whatever it is on the side of the motor? Where do I find the proper plates to replace the connections into the base of the cylinder and where the pump comes off? Also how far up do I remove the hose going to the air cleaner? Do you remove it and the valve mechanism next to the carburator or leave that canister on?
  • rkuckkahn
Posted February 08, 2006 - 07:32 AM
I bought a kit that had instructions for rerouting the hoses, and included the cover plates. Baha Designs has it (just checked) www.bajadesigns.com/NET/mainframe2.aspx?content=.
There are also complete instructions to do it all yourself on 4strokes.com too but their server has been down for a while. I just didn't want to mess with cutting my own block off plates but the kit is like $29. The whole mess comes off the side and makes the engine much cleaner. The only thing I noticed with the smog gone is no more backfiring (with all the other mods in place).
I assume you're doing all the other mods too. This bike is way lean, runs hot stock and needs to be opened up: snorkel, air filter, carb rejet, aftermarket exhaust or mod the stock exhaust. Gearing helped a lot too 14/47 works for me but it depends upon where you ride. With all the mods you can take off the wings and run at 220 degrees (oil dipstick temp).
  • HawkGT
Posted February 08, 2006 - 01:33 PM
Some info in this thread:
http://www.thumperta...&highlight=smog
  • 9 replies
  • 17 replies
Honda XR650L 2016
  • 0 reviews
  • Hot  35 replies
