Setting Sag
6 replies to this topic
  • bhollis426
Posted February 07, 2006 - 04:09 PM
Guys, What Is The Best Way To Set The Sag? Can Anyone Give Me A Play By Play Or Shoot In A Link? Thanks!
Posted February 07, 2006 - 04:36 PM
First,
http://www.tootechra...ension_tips.htm
Then,
http://www.tootechra...pension Tip.htm
  • Crabtree426
Posted February 07, 2006 - 08:28 PM
Grayracer, once again you've made technical question easy. That diagram is a lot easier then trying to explain it to someone. :thumbsup:
  • Matty05
Posted February 07, 2006 - 08:33 PM
Isn't that in your manual?
But cheers Gray for sharing!
  • sirthumpalot
Posted February 08, 2006 - 04:03 AM
Google for "SAGSetter". The DMGTek SAGSetter is the best sag tool I've ever used. Small changes in sag make a big difference so be precise!
  • Matt96xr6
Posted February 08, 2006 - 07:46 AM
http://ohlins.com/pdf/07251-02.pdf
Ohlins has some great setup tips for you in their manual. I would suggest to read it. Also how to set the sag.
Posted February 08, 2006 - 07:59 AM
While we're on about this, keep in mind that the sag in a cold garage is going to be different than it is in the middle of the day after the shock is warmed up. The fluid will heat and expand, which will compress the gas chamber, which in turn, adds to the total effective spring preload. Set it to drop about 20-30mm too far, and check it once it's warmed up well.
  • 0 reviews
  • Hot  47 replies
  • Hot  33 replies
