06 YZ450F, has too much...
25 replies to this topic
  • Blaster21996
Posted February 07, 2006 - 06:28 AM
POWER!
Here in Florida, the motor is excellent for the sand, however, I rode at Hardrock MX track yesterday, witch is a hard pack track (4 of them to be exact). I do not have the skill to control the power on a hard surface.
So, I can either keep my 05 YZ250F for hard tracks, or, find a way to cut some power off the 450 for the hard pack tracks.
Here are a few of my ideas..
A WR throttle stop screw
An over stuffed silencer
Does anybody have any other ideas?
(If you feel like this is an opportunity to post a wise A__ comment, please do :thumbsup: )
  • NYMXer
Posted February 07, 2006 - 06:35 AM
If you are having throttle control problems, why not just try riding a gear high? The bike will pull, just not as hard. Try it, you may like it.
  • Reyndogg
Posted February 07, 2006 - 06:39 AM
less tire pressure and a gear higher like NYMXer said
  • Drfletcherdc
Posted February 07, 2006 - 07:30 AM
Just change your rear sprocket from a 49 to a 47. That will take away the punch of the bike.
  • gholt651
Posted February 07, 2006 - 07:49 AM
There is a throttle tube on the market that allows you to control the power of your bike but I can't remember who makes it. It is aluminum and has three different setting to adjust it to your needs. I'm sure someone will chime in with the name. This is probably what you need. I thought the same thing when I first rode mine on a hard pack track,but the more time I put on it the more I love this bike.
  • SureBlue
Posted February 07, 2006 - 08:35 AM
G2 Ergonomics Throttle Cam System
http://www.procycle.us/main/g2.htm
  • KillerHiller
Posted February 07, 2006 - 08:43 AM
Other ways to tone down a bike ; flywheel wieght and a spark arrestor like an FMF Q.
As mentioned above, short shift!
  • Matt96xr6
Posted February 07, 2006 - 09:23 AM
Go ride an 03 on the hardpack. Then get back on the 06. Problem solved! You will love the smooth power of the 06 in comparisson.
Posted February 07, 2006 - 10:07 AM
Gear it higher, run it in a lower RPM range, and learn throttle control.
  • DirtMongrel
Posted February 07, 2006 - 10:18 AM
how bout turning your wrist a little less, its the cheapest way. its not fair to compare a 250f to a 450f and then complain about too much power. seriously though i had the same issue going from a kdx200 to a yzf426, i changed gearing and use less throttle, it works. you'll find the sweet spot and soon complain that your 250f has no power. funny how that works. good luck
  • jeffboyd47m
Posted February 07, 2006 - 03:51 PM
POWER!
If you think the 06 has too much power, Even with the Perfect Seamless delivery that it has, Then you my friend belong on a 250F!
  • perrymx23
Posted February 07, 2006 - 03:56 PM
Everytime the front end starts to come up SHIFT up. You'll be if fifth real soon and having a blast!!!!!!!!!!!! :thumbsup:
  • danath 34
Posted February 07, 2006 - 08:40 PM
thats always how it is when moving up to a bigger sized bike. just ride a while longer, get used to it.... if you put any restrictor on it, you'l just smack yourself in the head because once you get used to it, youl have to take the time to put it back stock, where you would rather be riding it. :thumbsup:
  • Matty05
Posted February 07, 2006 - 08:58 PM
POWER!
Don't restrict it!
throttle control and use the torque not hp, meaning short shift it!
You know it has the power to pull. :thumbsup:
  • Racing
Posted February 08, 2006 - 01:12 AM
Had the same problem when i bought my first 450 ('05) and used it for flattrack racing (Hardpack). Changed to a G2 Ergonomics Throttle Cam System,geared longer (went to a 47 rear), flywheel weight and a better rear tyre. Traction..traction...traction=fast.
  • jbrooks26
Posted February 08, 2006 - 02:22 AM
If you are that bent on it, I will trade you straight across for my 02WR426!! :thumbsup: :thumbsup:
Seriously, just ride it and you will get used to it. May take a few rides, but I'm sure it will work out.
Josh
  • ovrrdrive
Posted February 08, 2006 - 03:46 AM
No one else said it yet, but if you still have the stock tires on it they are not really good for any terrain at all. Especially the hard pack/loose pack/rocky surface at hard Rock.
I say get used to the bike and learn a little throttle control and change the tires.
I dropped a tooth on the front sprocket and still don't have trouble at Hardrock. And I'm a new mx rider. :thumbsup:
  • Blaster21996
Posted February 08, 2006 - 01:39 PM
I wish to thank all those that posted there thoughts on my problem. I took a couple of the posters advice and ordered the G2 throttle tube this morning, and just finished advertising my YZ250F in the paper for sale. :thumbsup:
  • shigbie
Posted February 08, 2006 - 05:14 PM
Turn your wrist less!
  • Farmer_dave
Posted February 08, 2006 - 10:21 PM
I had a big scare on my 450 (rmz) when I first got it after riding it more and more it dont scare me one bit now, just ride it mate and from what ive heard the 06 yzf 450 is the most user friendly of the lot do you should be fine.
  • Hot  36 replies
  • 10 replies
  • Hot  30 replies
  • On January 15, 2017
  • Hot  28 replies
