2003 YZF450 Suspension suggestions
7 replies to this topic
  • gardnpa185
Posted February 06, 2006 - 05:25 PM
I am switching over from 2-strokes to an '03 YZF450. What suspension mods would you suggest? I am a reasonably fast Vet rider who weighs 200lbs.
The last time I rode the bike the rear suspension felt pretty good, but the forks were harsh. The handle bars were almost ripped out of my hands on braking bumps.
Any advice is welcome.
Thanks in advance.
-Paul 185
  • Matt96xr6
Posted February 06, 2006 - 06:44 PM
First get the correct spring rates installed front and rear for your weight. After that get the forks and shock revalved to your specs. Be sure to work with the suspension shop and tell them what you want, what you dont like.
Personally did all that on my 450 for my buddy, then swapped out a set of 05 front forks on the bike. That is the ticket!
  • PK
Posted February 06, 2006 - 07:37 PM
Matt, what did you have to change to get the 05 forks on the 03? I would like to put a set of twin chambered Showa's on mine but I'm not sure if that's possible at a reasonable price. That is the main complaint I have with my 03, even after all the valving and spring work, it still sucks compared to my Honda's.
  • DPW
Posted February 06, 2006 - 07:53 PM
I would think all you need is the upper and lower triple clamps from a '04 or '05, but that is just a guess.
  • 450_rider
Posted February 06, 2006 - 09:50 PM
A little while ago grayracer was talking about how he put 04 forks on his 03, it was pretty interesting to read. I really thought about doing it, maby he will pipe in on this
Posted February 06, 2006 - 11:48 PM
Right you are. :thumbsup:
  • Gizabious
Posted February 07, 2006 - 12:06 AM
Thanks in advance.
-Paul 185
Try raising the fork oil height to between 110mm and 100mm makes a huge improvement, I'm about the same weight as you and found i could run the stock fork springs at 105mm of oil with no problems. 5.6 spring on the back should work well for your weight and ability
  • Ga426owner
Posted February 07, 2006 - 05:36 AM
Thanks in advance.
-Paul 185
I had the same problem.....sent the fork and shock to Enzo Racing....now it is perfect - with Subtanks :thumbsup:
Motocross
  • Hot  491 replies
  • 0 replies
  • 9 replies
