Why slide the forks up on 06?
6 replies to this topic
  • Jeff_Ashe
Posted February 04, 2006 - 06:54 PM
Admittedly, I only have one day on my 06 YZ450F. But I started out with Michelin MS3 in moderately sandy soil today, and there was no push or anything that indicated a fork height change needed.
Is the height change just people blindly following a magazine article or am I missing something?
Posted February 04, 2006 - 07:02 PM
Other guys have run into a bit of push, but it may have had to do with riding style, soils, tires, sag settings, or a number of other things. They cured it by pulling the forks up. :thumbsup:
What I find interesting is the feedback I here about how sensitive the bike is to small changes. You actually get noticeable results from the adjustments you make. It seems to me that would be easier to work with than to keep changing stuff and not seeing anything come of it.
  • Jeff_Ashe
Posted February 04, 2006 - 07:06 PM
I forgot to add that I have a brand new DunFlop 739 front tire for sale, cheap!
  • black_n_blue_thumper
Posted February 05, 2006 - 10:24 AM
I like the feel of it. It helps make the bike feel smaller to me. I did 10mm on my WR and it helped a ton for overall feel and handleing on it as well. :thumbsup:
  • debounce
Posted February 05, 2006 - 11:29 AM
The front tire causes a lot of the push, but if you slide up your forks and set your sag to 98mm, there is a big difference on the stock front tire. I don't know if there is a difference if you have a front tire that is suited to the soil you ride on, but it will still allow you to turn tighter.
  • jeffboyd47m
Posted February 05, 2006 - 12:09 PM
I have played with fork height quite a bit on my 06, Anywhere from flush to 15mm. I run my sag at 103mm as per Enzo racing recomends and run a 755 Dunlop on the front with cr high bend bars. The only time I have felt that the front end wanted to push was with the stock 739 tire. Other than that I just change fork height as needed for riding conditions.
  • Jeff_Ashe
Posted February 05, 2006 - 09:04 PM
Follow-up on raising the front forks... Rode a slightly harder soil today, close to medium but still on the soft side. Definitely was a slight push in the front. Raised the forks about 5mm, from the factory flush setting to the "first line visible" setting. Corners much better. No sign of head shake.
So I guess I am reinforcing the magazine articles and making the recommendation to raise the forks high enough to make the first line visible. Oh yeah, don't forget the Michelin MS3 if you ride medium-to-soft terrain. It just don't get no better! :thumbsup:
  • Hot  113 replies
  • Hot  50 replies
