Valve Cover
4 replies to this topic
  • locknload
Posted February 04, 2006 - 01:50 PM
Hi I want to check valve clearances on my 03 WR450 in the next few days. The manual says to remove the carb and the top engine mount. what has to be removed to get the valve cover off Cheers Doug :thumbsup:
  • tony1970
Posted February 04, 2006 - 02:36 PM
You can leave the carb on. You will need though is a small torque wrench if you need to adjust the valves to get in between the frame and the head. I have one that is a 1/4 inch SAE drive and it works well. Good luck.
  • 642MX
Posted February 04, 2006 - 03:25 PM
You have to remove the mount, but the carb should stay on.
  • locknload
Posted February 04, 2006 - 05:17 PM
Cheers guys gunna do it later on today :thumbsup:
  • Matty05
Posted February 04, 2006 - 07:28 PM
:thumbsup: Just undo the top 2 bolts, this is to give you enough room to get the cover off!
