Stock exhaust question....
4 replies to this topic
  • Scott_in_KC
Posted September 16, 2001 - 08:13 AM
Taking the end cap off and looking inside it appears to be a straight shot right through the can, with only the huge spark arrestor in the way. Is there something inbetween the header pipe & silencer, in that flanged area right before the silencer that I can't see, internal baffle or something? Just curious. I have read all the exhaust posts in the archives. Just seems like there should be an easy way to slip a different core in there and add some packing perhaps? Just thinking. I thought if nothing else that spark arrestor could be cut down by half and get rid of the solid end piece.
  • Scott_in_KC
Posted September 17, 2001 - 02:53 AM
Never mind. I got a flashlight and probed around in there, I see the baffles back in there.
Has anyone tried drilling these out (like the DRZ guys do?)
Probably grasping at straws...might as well just get the e-series if it's gonna be this loud.
  • wayneoXCF
Posted September 17, 2001 - 03:26 AM
Scott-
Some guys go with the vortip, although I dont think the difference is that great. It is kind of loud, but you should see the 2 smokes scrambling to get out of the way!
I have drilled the sh** out of my stock baffle, but only use it when Im putting around the neighborhood.
  • mcarp
Scott-
People just don't fuss with the stock anchor too much. They are just WAAAY to heavy to consider a permanent addition to the bike, so folks investment in personal R&D with it isn't much!
With YZ timing, the shape of this pipe is off by a longshot-performance will not be nearly the same as if using a stock YZ pipe.
The baffles are there to help increase backpressure slightly for good low end performance. Take those away and so does your low end.
  • Scott_in_KC
Posted September 17, 2001 - 03:37 AM
Sooo...if I keep the WR timing so I want a different pipe?
