XR628 - Mikuni Flat slide (non pumper) v Kehin FCR
3 replies to this topic
  • rmhrc630
Posted January 31, 2006 - 05:13 PM
what carby would be better?
The FCR costs about $1200 all up
The mikuni flat slide non pumper is about $440
Can anyone describe the differences each of these carbs makes to the XR628?
I am leaning toward the mikuni as it has good reports plus lot cheaper and seems more sorted for my application.
What are the real differences in power between the FCR and the mikuni flat slide non pumper?
  • XR250rdr
Posted January 31, 2006 - 06:23 PM
You should be able to pick up an FCR for quite a bit less than $1200, especially if you can find a used one. They only run about $600 USD here for the whole kit.
EDIT: Thought you had an XR650R...the XR600 kit runs a little over $500.
  • rmhrc630
Posted January 31, 2006 - 06:35 PM
whats a better carb for the buck?
is the FCR that much better than the mikuni flat slide non pumper?
I've heard the FCR makes the XR chew the fuel?
  • goblin127
Posted February 01, 2006 - 06:23 AM
XRs only sells the mikuni flat slide for 230.00 With some of there magic done to it.
  • 3 replies
  • 9 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 4 replies
