Valve cover gasket - 03 WR450
9 replies to this topic
  • brianjw4
Posted January 31, 2006 - 12:01 PM
Does the valve cover gasket have to be replaced each time the valve cover is removed?
  • Indy_WR450
Posted January 31, 2006 - 12:37 PM
no need to ever replace it unless it is damaged.
  • brianjw4
Posted January 31, 2006 - 01:14 PM
Great, thanks for the reply. I'm going to check the valve clearance, I can leave the spark plug in for this procedure right?
  • Indy_WR450
Posted January 31, 2006 - 01:44 PM
You can leave it in. :thumbsup:
  • brianjw4
Posted January 31, 2006 - 01:55 PM
Thanks Indy.
  • BEAN329
Posted January 31, 2006 - 07:31 PM
Indy, where did you get your big bore kit from?
  • brianjw4
Posted January 31, 2006 - 07:37 PM
I checked my valves and my intakes were around 10mm, maybe a little more, but the 15mm guage definitely wouldn't go. My exhaust valves were at 20mm. I'm assuming this will be alright for the short term, a ride or two, should I set them at the top of the range soon (15mm intake and 25mm exhaust)?
  • Indy_WR450
Posted January 31, 2006 - 10:30 PM
Max Power in Madison Wisconsin:
http://www.maxpower-...com/default.htm
  • jbrooks26
Posted February 01, 2006 - 01:02 AM
If they are within specs then I would leave them alone until they go out of spec. Just my 2c. Hope this helps.
Josh
  • jrcgaf364
Posted February 01, 2006 - 01:09 AM
wow i think this is the one of the first threads with no smart a$$ replys....good job guys :thumbsup:
