Header Pipes
9 replies to this topic
  • camaro345
Posted January 30, 2006 - 04:05 PM
I'm going to be getting a new exhaust system, don't know for sure what, but my question is, is a titanium powerbomb header worth the extra $100 or should I just go with a stainless steel one. I know my stock titanium header dents very easily when the pipe is hot, will the titanium powerbomb do the same thing?
  • Indy_WR450
Posted January 30, 2006 - 06:31 PM
Oh Yeah go with SS powerbomb. Ti heat cycle fatigues at the high heat found on the first foot of header. Ti is great for the slip on after the header. :thumbsup:
  • clark4131
Posted January 30, 2006 - 07:08 PM
When I bought mine, there were two versions, SX and MX. The SX is supposedly tuned for better low end, and the MX for the high end. Whether it's true or not, I don't know, but I got the SX and I'm happy...SC
  • Indy_WR450
Posted January 30, 2006 - 07:24 PM
SX version as well for better bottom end! :thumbsup:
  • camaro345
Posted January 30, 2006 - 08:06 PM
How much of a differenece, if any, is there in power with a powerbomb header over a stock header?? I would probably get the SX for more bottom end. Is the $150 worth it?? Or should I just use the stock header with a slip on??
  • Indy_WR450
Posted January 30, 2006 - 09:07 PM
You can get the header now or later. The stock header will heat cycle fatigue and collapse in about a year of riding. Then replace it with the SX - SS Powerbomb. :thumbsup:
  • Joe_dirtbiker
Posted January 31, 2006 - 10:32 AM
I just ordered my powerbomb yesterday ($190 from DennisKirk). Good to read about the heat fatigue. My none-to-old header pipe buckled and then ripped at the buckle folds last ride. I was thinking it seemed like that pipe didn't last near long enough. 3yrs old, 1700miles.
Hoping I can hose clamp the stock heat shield on to the powerbomb.
  • kirkw
Posted February 02, 2006 - 05:08 PM
Like Indy and SC I have a SS Powerbomb SX mated to a Q. It does have better low end than stock. Seemed to make no difference on sound output though.
  • OneToGo
Posted February 02, 2006 - 11:31 PM
Hi
I did a lot of reading and research before I decided on a replacement pipe for my WR. :thumbsup:
Brand names aside, it seems that the TI headers do fatigue and are prone to denting more easily than Stainless Steel. By comparison, the weight saving you achieve with a Ti header compared to SS is not worth the extra $ (IMHO). I agree that anything after the header is OK, be it carbon, Ti, Alu or SS. It depends on how much noise you want vs. performance and looks/fit/weight! - there is and will be atrade-off to some extent with these. I also went for the powerbomb but mated with a Q2 (a noise issue) - it comes with a PowerNow insert - the combo apparently restores mid to low end. While this combo may not be the best for performance, I think it gives good power gains over the stocker at only modest noise increase - still legal and wont upset the neighbours.
My .02 / Hope this helps
Colin
  • camaro345
Posted February 03, 2006 - 08:42 AM
Thanks for all the great info, this is what I was wanting to know.
