Need More Power for XR650R. What Mods Next?
9 replies to this topic
  • DualSport650
Posted January 29, 2006 - 07:03 PM
Hey TT'ers,
I'm getting the BRP ('01 XR650R) ready for the riding season.
I love this bike, but I think I'll love it even more with a tad more power.
Here's what I've done so far to it...
* Un-Corked everything (Airbox, Carburetor Manifold, etc.)
* Edelbrock Carburetor (it's adjusted and jetted properly)
* Uni Air Filter with XR's Only Backfire Screen
* Drilled holes in airbox cover, installed Uni filter inserts
* Installed Yoshimura RS-3 Slip On Muffler
So, I'm thinking my next steps are to buy a HEADER that flows better, and install a Hotcams Stage I cam. :thumbsup:
I think those 2 next mods (HEADER & CAM) will make the bike RIP! :thumbsup:
What header would you recommend that will work with the Yosh?
(No, Yoshimura doesn't make a header for the XR650R) :bonk:
I hear the FMF "High-Flo" Header will fit and gives the bike some mid-top end boost.
Let me know what you think. Thanks...
  • Mudshark
Posted January 29, 2006 - 07:17 PM
Yup, I'm going the FMF Hi Flo route as well. Sweet looking header.
Ths larger diameter pipe will do a great job of boosing the top end
output.... I just don't want to lose any bottom end grunt thpugh.
  • DualSport650
Posted January 29, 2006 - 07:26 PM
Right On MudShark,
I think we'll loose just a little on the bottom with the FMF High-Flo, but I don't really care since I ride in the WIDE-OPEN Desert out here in Central Oregon.
I'm looking for more MID to HIGH RPM power and the new HEADER and CAM will definitely do the job.
I just want to make sure the FMF High-Flo is the way to go...
  • 767driver
Posted January 29, 2006 - 07:33 PM
There is one other thing you can try. It's a small thing but they all add up.
Put a bead of grease around that new Uni filter and take off that XR backfire screen. The Uni filter should have a support built in that will enable it to stand alone. The XR backfire screen is really designed to operate with a stock type foam filter.
That little extra airflow will be beneficial in the end. Hope that helps.
  • goblin127
Posted January 29, 2006 - 08:20 PM
A bottle of nitrous.
  • DualSport650
Posted January 29, 2006 - 11:00 PM
Nitrous?
OK, but AFTER I install the TURBO! :thumbsup:
  • Modsport02
Posted January 29, 2006 - 11:26 PM
Also you might want to look into a pro-circuit header, I got one on my 01' 650r and it working awsome for me.
  • iestrada
Posted January 30, 2006 - 10:00 AM
go for the hotcams stage 2, gives the bike more bottom torque :thumbsup:
  • DualSport650
Posted January 30, 2006 - 10:30 AM
Hey iestrada,
Cool idea, but I heard the Hotcams Stage II cam shortens valve train life! :bonk:
I don't want to go there. I want to maintain the rock-solid reliability, but just open up the engine's breathing to make a bit more power.
Looks like I'm going with the FMF High-Flo Header and the Hotcams Stage I cam. :thumbsup:
  • Maximus86
Posted January 31, 2006 - 03:04 PM
whats the difference between stage 1 and stage 2 hotcam-besides the honda HRC cam what other cams are available?
