06 450.. What is stock handle bar bend?
9 replies to this topic
  • jgerdi
Posted January 27, 2006 - 12:24 PM
I picked my 06 limited up yesterday. It feels like my 04 crf250 only with a geeked up motor. I rode at a friends practice track, tight no berms single rut for the inside corners. It feels as light as my 250f and I can't say that my crf didn't have the same push.
Any way I want to order some pro tapers and trying to compare the height and pull back. I like the pull back on the stock bars but it is said that taller bars help the 450. I did not notice any name on my bars under the pad. Does anyone know what bend is stock on the 06 450
  • beezer
Posted January 27, 2006 - 12:33 PM
GYT sells taller bar risers for the YZ. I ordered mine from my Yamaha dealer.
  • jgerdi
Posted January 27, 2006 - 12:43 PM
In pensacola the dealer gets retail plus and does not carry any bars,chains,sprockets,levers.
How much were the bar mounts?
  • beezer
Posted January 27, 2006 - 01:35 PM
I don't even know to be honest.
I figured risers were much easier and cheaper than bars.
Lots of Yamaha parts on the net though.
  • zcookie49
Posted January 27, 2006 - 05:00 PM
are the stock risers 35mm height?
Pro taper sells the risers in 35,45,55 mm heights. Recomendations appear to go up 10mm from the stock set up... $60 for the pro tapers.
  • DPW
Posted January 27, 2006 - 06:29 PM
Do you have specs as far as how much taller and forward the new ones are vs. stock?
Also do they look like the stockers?
  • DPW
Posted January 27, 2006 - 06:34 PM
I think the risers on the Pro Taper site are for their clamps..not the OEM Yamaha clamps.
  • mxmark
Posted January 27, 2006 - 10:11 PM
I called Yamaha today and they did not have the specs. They did not even have the part #'s. The number for the risers is GYT-2S275-10-00 Retail is like 60.00. Thank you Mark
  • mitocross
Posted January 28, 2006 - 04:09 AM
The stock bars are close to the Carmichael ProTaper bend. That is the starting point. :bonk:
I bought CR-Hi bend,they are higher and I like more sweep too.
:thumbsup:
  • DPW
Posted January 28, 2006 - 06:11 AM
thanks..for the info Mark. I may just order the parts and see what happens.
