What should I look for? On a 4stroke it would probably be a head gasket but on a 2stroke should I be looking for the leak around the water pump shaft? Throw me some ideas what to look for as I tear into it. thanks
by the way it's my sons kx80.
coolant in the oil
Started by
drewpeacock
, Jan 26 2006 08:40 PM
7 replies to this topic
Posted 27 January 2006 - 01:25 PM
coolant really should never get in your oil, i have a kdx and the cooling system really doesnt have a spot to enter the motor, except were the shaft is that spins the coolant fan. Does the bike have a coolant fan, by fan i do not mean electric it just circulates the coolant.
Posted 30 January 2006 - 11:12 AM
Posted 01 February 2006 - 04:43 PM
what year bike?there bad about the head getting warped,i have a cheep fix to this problem,could be the base gasket also.
Posted 02 February 2006 - 12:20 PM
the shaft and bearing had worn on my kx60 (right after i replaced the friggin gearbox). The shaft was really expensive but it was easy enough to fix.
