YZ400 popping on decel
8 replies to this topic
  • theclone
Posted January 26, 2006 - 02:02 PM
I know I need to adjust the pilot jet, but that's as far as my knowledge goes. Anyone wanna help?
EDIT: w00t! silver member!
OK back on topic...
  • flintlock28
Posted January 26, 2006 - 04:10 PM
Don't overlook the Fuel Screw.....
This time of year, with the temperature fluctuating, you can have the fuel screw off by a little bit, and she will backfire on deceleration.
I was at the track Sunday, and my bike was backfiring on decel. gave about 1/4 turn out, and no more backfiring. Try this first.
  • theclone
Posted January 26, 2006 - 04:59 PM
OK, that's what I thought at first, but after doing a search I thought it was the pilot jet. So how do I go about doing this? I got tired of searching through the manual, so that's why I am here. :thumbsup:
  • kawirider
Posted January 26, 2006 - 06:24 PM
could be a leak in your exhaust or carburator
  • FlashGordon
Posted January 26, 2006 - 07:40 PM
Try a 48 pilot jet, with 2 turns out on the fuel screw. Made my de-accel pops go away.
  • flintlock28
Posted January 26, 2006 - 07:46 PM
The Fuel screw is a recessed screw that is on the bottom of the carb., closest to the handlebars. It is a pain in the azz to adjust, since it is recesed. You generally have to get a stubby screwdriver, and then you have to grind down the screwdriver so that it's even shorter to fit.
The best $ 20 or so you can spend is for an Aftermarket fuel screw replacement, like the Zip-Ty model that I use. You simply remove the stock recessed screw, and install the Zip-Ty, which is a longer screw that has a knurled knob attached that also has graduated numbers on it. Now you no longer need to carry around a short screwdriver with you, you simply reach down and turn the Zip-Ty fuel screw by hand. It can make a big difference as to how crisp the throttle response is from idle to about 1/3 of throttle, it also will eliminate deceleration backfiring, if the carb is jetted reasonably where it should be.
http://www.ziptyraci...ryID=110&order=
  • swatcie
Posted January 26, 2006 - 08:35 PM
I think it is normal for the yz400s because the one I had did the same thing. It also used to shoot flames out the exhaust lol! :thumbsup:
  • theclone
Posted January 26, 2006 - 08:48 PM
thanks! that's the info I needed. :thumbsup: :bonk:
A little off topic but I thought this was funny. I saw this on the page you linked me to:
Please note that some of the DR-Zs - streetlegal - do not have the Keihin pumper carb - at least what we've seen in California (for our stringent - read: ridiculous - emissions laws).
:thumbsup: ridiculous is an understatement
  • palmdaleRider
Posted January 26, 2006 - 09:11 PM
Just a thought, try some STP carb cleaner. Mix 2-3 ounces in a tank and run fast. Might clean up some deposits. My bike use to backfire like a fiend and this sort of simple treatment has done wonders.
  • Hot  30 replies
  • 10 replies
  • Hot  28 replies
  • On January 15, 2017
