Brake Shoe Replacement Recommendations
10 replies to this topic
  • jbrooks26
Posted January 26, 2006 - 06:08 AM
Hey Guys,
Anyone have any suggestions for brake shoes out of the selection here in the TT Store? I ride trails 100 percent of the time, and my stock shoes are about shot. What type/brand should I go with? Thanks,
Josh
  • Fryboy
Posted January 26, 2006 - 06:46 AM
Do not go with EBC unless you want to listen to them squeal during hard braking. It drove me absolutely crazy! I have heard that the stockers are the best but I am trying Galfers this go around. Unfortunately I can't give you any report if they are better at this time.
  • WGP
Posted January 26, 2006 - 07:21 AM
I'm using the Organic EBC pads :thumbsup:
The stock ones are junk if you ride technical stuff.
  • SJMC_DON
Posted January 26, 2006 - 08:25 AM
I've always gone with EBC Sintered Base, they last a long time and I have never had squealing issues :thumbsup:
  • unkle_george
Posted January 26, 2006 - 09:11 AM
Sintered Base pads only work well when they're hot and dry. They're awful when they're brand new and wet. (Read .. no brakes at all). I got in the habit of dragging the front brakes all the time just to dry them out.
Yamaha OEM's are about the best.
  • SJMC_DON
Posted January 26, 2006 - 11:02 AM
I disagree Unkle George......... my Sintered Base pads work well in all conditions :bonk:
To each his own I guess........
And when I think about it, I'm pretty sure the OEM pads on my 04' were sintered base pads. I got two years out of em' :thumbsup:
  • jbrooks26
Posted January 26, 2006 - 03:13 PM
Thanks for the replies guys. Anyone else, a real mixed bag of opinions here so far.
  • Indy_WR450
Posted January 27, 2006 - 04:41 AM
EBC sintered! No squeals. :thumbsup:
  • Fryboy
Posted January 27, 2006 - 05:43 AM
:bonk: I dunno I ran the same ones, no squealing on front but the back howled like a freakin wolf under heavy downhill type braking. I replaced rotor with Wave and it still squealed. Blue_One.... back a brotha up :thumbsup:
  • brutis1984
Posted January 27, 2006 - 09:16 AM
The ceramic coated moose pads provided a noticeable increase in braking performance and control over the stock pads, no sqeak or fade and perfect function in all conditions. Ive got 1000mi on them and they are still nice and thick. Also it helps to replace the stock brake fluid w/ high temp fluid, those together you will notice a tremendous difference. :thumbsup:
  • mtrablue
Posted January 28, 2006 - 07:43 AM
you said you wanted to stay with the TT store. if your still sure of that, look for the ebc "mxs" pads. the full on ebc sintered will squeal when they get dirty and hot. they've squealed on every bike i've had 'em on. i've worked a lot of enduro and hare-scrambles check points and you can hear a set of ebc sintered pads coming a long ways away. if your not tied to the TT store, look at the rockymountain tusk sintered. i tried them on a lark. i figured at 15 bucks, they'd make a good back up set for my tool box. i put them on one ride and haven't taken them off yet. be sure to use the little sheet metal and fiber piece from your oem pads(i know they're on the rear, don't remember if they're on the front).
