best oil and coolent?
11 replies to this topic
  • WR400Fdunk
Posted January 25, 2006 - 10:06 PM
whats the best oil and coolent, about to do a full fluid change and clean up the bike... anything info will help.. thanks
  • Matty05
Posted January 25, 2006 - 11:07 PM
Evans NPG-R coolant is super! Contains no water.
As for best oil, 100% synthetic is best.
People use everything here, I can only afford semi-synthetic oil, so I run Motul 5100 15W-50. Oil is expensive here in Aust.
  • boer
Posted January 26, 2006 - 01:12 AM
So is any good motor car engine oil good for the bikes with joint engine/tranny oil or does it have to be a proper bike oil? :thumbsup:
  • pkcof
Posted January 26, 2006 - 02:33 AM
i'm with matty05 on the oil also, Motul 5100 15W-50 and i reckon it's as good as anything else - anyway i change it every three rides (250 klm) so why spring for the big $$ stuff if you're only gonna throw it out ?
  • byggd
Posted January 26, 2006 - 05:06 AM
For oil I run Rotella T.....it's a full synthetic, recommended by Rekluse, and you can get it at Walmart for 12-14 $$ a gal :thumbsup: Any oil is good as long as you change it often enough and as long as it doesn't have friction reducers, there are bad for a wet clutch :bonk:
  • bg10459
Posted January 26, 2006 - 05:39 AM
Evans NPG-R is great if you have cooling problems, but it actually doesn't transfer heat as well as straight distilled water, and it's fairly expensive when you factor in the flush that's needed also. If you don't have over-heating problems, use distilled water and just enough anti-freeze to obtain the desired level of freeze protection. I also use water wetter, which improves the heat transferability of water.
Any non-EC oil, changed frequently (between 5 and 10 hours) should perform well. I use Rotella T, change oil every ride, filter every other ride.
  • WGP
Posted January 26, 2006 - 07:27 AM
Thumper Semi-Synthetic Racing Oil
http://www.belray.co...es/Thumper.html
Engine Ice
Be careful with the Evans Coolant, I believe it doesn't have freeze protection if you live where it freezes.
  • Matty05
Posted January 27, 2006 - 08:03 PM
Do a search and you will find which car oils people are using and how to pick a good oil. Heaps of people like to use that shell rotella and mobil gold cap stuff.
We don't bother in Australia using car oils, they are more expensive than the good bike specific oils. Be careful, nearly all car oils have friction modifiers which make the clutch slip.
  • Ibis
Posted January 28, 2006 - 11:35 AM
Evan's NFG coolant is propylene glycol without any water.
Boiling point is 367º F
Freezing point is -79º F
Freezing is not a problem, but the high boiling point could be.
  • farkawi
Posted January 30, 2006 - 04:40 PM
You'll likely get 10 different answers from 10 different riders on their oil preference. I have no brand loyalty in oils to speak of. Motorcycle specific full synthetics are my preferred lubes; especially for bikes that share engine/transmission/clutch oil. My Yamaha manual specifies SG rated petroleum oil as the minimum standard.
  • 642MX
Posted January 30, 2006 - 05:58 PM
I thought Rekluse only recommended Shell Rotella 15W40 and Chevron Delo 400? Maybe I'm wrong.
BTW, I use the cheap green coolant and Rotella.
  • Indy_WR450
Posted January 30, 2006 - 06:27 PM
Delo 400 was revised & improved last year with the "good" moly that wont accumulate on our friction plates. I have been using it for over a year now with the rebuilt motor and Rekluse with Hinson baskets with recent inspection there are no signs of wear! I am impressed with $9.00 per gallon diesel oil! :thumbsup:
