play in the rear wheel
5 replies to this topic
  • jonmcevoy
Posted January 25, 2006 - 08:39 PM
I just got done replacing the rear wheel bearings. The manuel said there would be some axial play in the wheel. There has to be a 3/8 in of play from left to right. The sprocket is hitting the weld on the swing arm. Any thoughts, or is this normal? Thanks.
  • kawirider
Posted January 25, 2006 - 08:53 PM
Maybe you did not replace them correctly. Is your axle all the way through, and are your chain adjusters adjusted? That would be the first things I would check. 3/8" is huge, and you probably just installed them wrong.
  • Diode663
Posted January 26, 2006 - 12:18 AM
Im not sure how you would end up with 3/8s of play after installing them. They press straight in. Unless you pressed the inner race of the bearing and damaged the bearing. Take it out and see if there is play in the bearings. If there isnt then it is something else.
  • rav600nrt
Posted November 27, 2008 - 02:56 AM
check your spokes. I had similiar problem. I thought it may be wheel bearings, the spokes were loose instead. good luck.
  • matt4x4
Posted November 27, 2008 - 07:53 AM
if it was his spokes, how could the sprocket hit the swingarm???? :bonk: :bonk: :bonk:
Did you get the right bearings???? Sounds like there's huge play between the axle and bearing which would mean wrong sized inner race....
Unless like stated above - it's either :
not tightened yet
not centered with the adjusters
you messed up your bearings as stated
When putting in new bearings, there should be NO play once everything is back together tight...
Posted November 27, 2008 - 09:29 AM
This thread is nearly 3 years old.
  • Hot  38 replies
  • 10 replies
  • Hot  30 replies
  • Hot  36 replies
