wr/yz stator swap.....help!!!
28 replies to this topic
  • slopoke
Posted February 06, 2006 - 10:35 PM
#21
what exactly did you have to do?? i'm ordering my wr426 stuff tomorrow...need to know!!!...lol...thanks
  • essex426
Posted February 09, 2006 - 12:43 PM
#22
This was the reply i got from electro sport,after asking about the wiring. The pink wire gets split in half. The half connected to the stator will feed out as your new lighting wire (this mod is to convert the stator into DC and charge a battery). The other half of the pink wire still attached to the connector will now be an external ground wire. Ground this to your frame or side case. They have got a diagram on their website too.If you dont want to use a battery,i think you just do the pink wire mod and put a voltage regulator in, connected to the live(yellow)wire.The other regulator wire goes to ground.It worked on mine, but check it out properly before you do it.It just means you spend some time on the net, it's better than messing it up.Good luck.
  • worxster
Posted July 31, 2006 - 07:01 AM
#23
Hi chaps Question?
Can i use a wr426 stator (Genuine Yamaha ) on my YZ426 with the standard yz flywheel ? will it work ?
If so are the units plug and play ? Sorry for the dumb ass :thumbsup: question i am not to jacked on electrical at all.
  • essex426
Posted July 31, 2006 - 09:44 AM
#24
Hi chaps Question?
No they are different sizes.You have to use the WR flywheel too.
  • worxster
Posted July 31, 2006 - 10:18 AM
#25
Cool thanks for the info :thumbsup:
Regarding that mod will i require any other wr parts that i am unaware of ?
PS. does it plug in or is a wiring mod required if so any info regarding wiring?
again many thanx
  • essex426
Posted July 31, 2006 - 01:08 PM
#26
again many thanx
If you are fitting WR f/w & stator to run lights, then you will want a voltage regulator,i used a WR one.
You need to do the pink wire mod.
Ie: cut the pink wire and connect the end that leads to the block connector, to the frame ground.Otherwise it wont run.Tape up the other end.
Electrex do a wiring diagram, they say to unsolder a wire on the stator,but i don't think you need to unless you want to use a battery.You could check their website.
Tee into the yellow with the regulator, Yellow wire is power for light etc.
Hope that helps.
  • worxster
Posted July 31, 2006 - 10:47 PM
#27
Thanx Again For all help will let you know the outcome.
  • worxster
Posted August 02, 2006 - 07:44 AM
#28
Hope that helps.
ESSEX426 :thumbsup: thanx for the help bro all in and working vitually plug and play
Over all cost +- 280USD
  • essex426
Posted August 02, 2006 - 10:36 AM
#29
Nice one.
Glad it worked ok.
  • On January 15, 2017
  • Hot  38 replies
  • Hot  113 replies
  • Hot  50 replies
  • Hot  30 replies
