06 450...Looking for 90/100 front tire.
6 replies to this topic
  • jgerdi
Posted January 24, 2006 - 04:25 PM
I pick up my 06 Thursday. I've ridden the yzf and rmz back to back. YZ all the way. With alittle help on cornering this will be awesome. They say put 90/100 on the front however, I like ms3's here in fla.. I cant find any 90/100 in that series. In my motosport catalog they show bridgestone and dunlop with the only 90/100's . If I run an ms3 on the rear, which (bridgestone , dunlop) would be better for good ol sandy fla.?
Posted January 24, 2006 - 04:33 PM
First, who says put a 90 on the front?
Second, if I remember right, the 90/100 Dunlop is a 739, for hard surfaces, and the Bridgestone is an M601, for intermediates. Obvious choice IMO.
Personally, I would pull the forks up to the first line, where they belong, and run a Dunlop 756 or 773, or a Michelin equivalent, maybe an M401 B'stone, in 80/100 as a first choice for somewhere loose and sandy.
  • RCannon
Posted January 24, 2006 - 05:56 PM
Dunlop now has a 742 in the wider size. I own one but have ridden so little on it that I would hate o say it is the perfect tire. So far, so good.
  • Ga426owner
Posted January 24, 2006 - 05:59 PM
first who is "They" ?
I use 80/100/21 MS3's only and they work fine...
raise the forks and try a taller bend handlebar - that tire will work perfectly fine :thumbsup:
  • RCannon
Posted January 24, 2006 - 07:03 PM
I believe the real secret is going to be tripleclamps that change the offset. Two mm less offfset turns the YZ into something that will turn like you cannot imagine.
  • SM421
Posted January 24, 2006 - 08:44 PM
Assuming your are considering a 90/100 front tire because it is wider, you could go to a 90/90 as in a Michelin S-12 (works great in Florida) and have the wider tire your looking for. It would end up being about 9mm shorter than a 90/100 but you could adjust your fork height to compensate if needed.
  • aford541
Posted January 25, 2006 - 06:52 PM
Dunlop 742
I use the 90 and it works great!
  • Hot  38 replies
  • 10 replies
  • Hot  47 replies
  • Hot  50 replies
