KX60, and KLX110?
3 replies to this topic
  • DirtRider467
Posted 24 January 2006 - 03:50 PM
Ok, I'm just wondering, but will any parts from a 110 fit on the KX60?? Like the shock, wheels, etc. And if I got some KLX110 spokes, and rims, would I have to use a 110 hub or could I use my 60 hub? Thanks  :thumbsup:
  • docweedon
Posted 25 January 2006 - 11:37 AM
The triple clamps will work from the 110<->60, but why would you want to swap from the 110 to the 60?!  Usually people swap the forks from the 60 to the 110.
The plastics are the same as the 65 though.
  • DirtRider467
Posted 25 January 2006 - 11:55 AM
Its not that. I bought a kx60, and just want to know what 110 parts will fit on the kx60. Because i got it for 250 w/o the wheels, and forks. Thanks for the help.
Also does anyone know if the seats on the 110/65 are the same as the 60? Thanks!
  • docweedon
Posted 25 January 2006 - 03:43 PM
The seat on the 60 is completely different than the 65/110.  Like I said...the plastics are the same as well as the seat on the 65/110.
The only thing that can be taken off the 60 and put on the 110 is the front forks, front brake cable, front wheel/front brake drum, triple clamp and thats bout it.
But you can put the 65 front end onto a 110, but it takes some modifying the steering stem from the 65 to make it long enough to fit into the 110 head...or you can buy the 65/110 conversion kit for around $450.
