who is running a 51 tooth rear sprocket?
10 replies to this topic
  • WR400Fdunk
Posted January 23, 2006 - 11:15 PM
who is running a 51 tooth rear sprocket on there WR400 and whats the likes and dislikes?
  • Bamster
Posted January 24, 2006 - 05:27 AM
I use a 51 tooth rear and switch from a 14 front to a 13 when riding really tight trails. Works for me. :thumbsup:
  • HamBonE_23
Posted January 24, 2006 - 07:10 AM
I also run 13/51. It's VERY peppy!!! Have to be a little careful as the front wheel comes up very easy in first and second.
  • Tucker99
Posted January 24, 2006 - 01:29 PM
I got a WR450 and running a 52 on rear and left the front stock. I don't think a 13-tooth primary will last long. I also have an auto clutch with lets you run a taller gear. I'm in second gear in the real tight stuff. Perfect. This mod was recommended in Trail Rider Magazine.
  • alfie
Posted January 24, 2006 - 01:49 PM
I'm running a wr426 and i find that a 52 tooth rear sprocket helps tighten the gears up a bit allowing to say in second longer when I'm riding in tight woods
  • ToooFaarOutt
Posted January 24, 2006 - 02:09 PM
I am 210 lbs fully suited to ride and I am running a 14/51 on a 01 wr426. It seem to be really a good combo for desert as well as tight woods riding, hills climbs etc. Bike has good low end as well as top end and does not bog on hills.
  • NuckingFuts
Posted January 24, 2006 - 05:51 PM
Ditto! :thumbsup:
  • 450high
Posted January 25, 2006 - 02:43 AM
I run a 53 rear and 14 front.This is the best change i have made to my wr 450 for climbing steep hills and it,s a blast on the trails and tight stuff.
  • pclans
Posted January 27, 2006 - 10:31 PM
Running 14-50 on my 03 WR450. I think its great. Standard here was 15-50 but heaps better now. I am in New Zealand. Cheers :thumbsup:
  • alfa
Posted February 01, 2006 - 04:07 PM
I run a 51 and I don't need to really shift all that much. It works real well on tight trails.
  • unkle_george
Posted February 01, 2006 - 04:31 PM
I found that off road high speed sections I could pull about the same speed 4th or 5th. (Rev limit vs Bog) I changed to a 52 and then I could get up to speed in 5th faster.
(You know, that one 1/8 mile section of straight in the whole hare scramble ... You've gotta optimize for that. : )
