JD Jet Kit = Throttle Response
11 replies to this topic
  • 642MX
Posted January 23, 2006 - 05:52 PM
I just got done installing my JD jet kit. All I can say is WOW, thats the throttle response I was looking for. If your on the fence about a jet kit, I highly recommend this one. :thumbsup:
  • Florida_426
Posted January 23, 2006 - 06:41 PM
I'll second that thought, I did the JD kit last summer and it makes a world of difference. JD even anseweed my emails same day to help me with some questions. I also got the JD Jetting software form the TT store, good stuff.
Bill
  • bg10459
Posted January 23, 2006 - 07:24 PM
The JD kit is great, and JD is even better with customer support. :thumbsup:
  • Shwantz34
Posted January 24, 2006 - 07:18 PM
Thank's guys for the information, i think i will order one, i just put a quick shot a weeks ago , and i will receive my new Thunder Alley exhaust pipe in about a week , i think this kit will be the cherry on the cake.
  • racer8
Posted January 24, 2006 - 10:24 PM
The JD jetting kit,what all is included with it?
  • WheelsUp
Posted January 24, 2006 - 10:25 PM
Two triple-tapered needles and four main jets.
The "magic" is in the needle shape.
  • kawirider
Posted January 25, 2006 - 12:01 AM
Does itcome with any sort of guide on what to do? Does it come with pilot jets?
  • WheelsUp
Posted January 25, 2006 - 01:52 AM
No pilot or leak jets.... those need to be fine-tuned by gauging from the fuel screw. More than about 2.5 turns out and you should move up to the next larger pilot. Less than 1 turn out and move down.
It does come with a simple instruction sheet with a recommendation based on your altitude for where to start on the main and needle clip.
Of course, James Dean is an active member here and more than happy to answer questions.
  • Ga426owner
Posted January 25, 2006 - 02:42 PM
I have it in my 03 and it really does work well once you get the jetting right especially if you run U4 exclusively.....until then it only helps in certain areas....adversely affecting other areas. (but when it is right....hold on, it is a awesome rush)
I am wondering if there is a 06 owner experimenting with this kit or if it is even the same as the other YZF kits...
  • kawirider
Posted January 25, 2006 - 03:09 PM
Well which kit has pilot jets too? I was about to buy a JD jet kit for my dads WR, because his fuel screw is like 4 turns out right now :thumbsup:
  • 642MX
Posted January 25, 2006 - 04:38 PM
I don't think any jet kits come with pilots. 4 turns out means you need the next size larger pilot jet.
  • WheelsUp
Posted January 25, 2006 - 06:48 PM
4 turns, I'd consider buying the two next larger sizes, but first make sure the existing pilot is clean. The hole is VERY small... barely large enough to see light through, and it blocks very easily from contaminated fuel.
  • Hot  30 replies
  • 0 replies
  • Hot  28 replies
