Is anyone else breaking choke knobs?
10 replies to this topic
  • Joe_dirtbiker
Posted January 23, 2006 - 12:15 PM
I'd had an 03 WR450 for six months/1000miles. I bent my choke knob in an unintentional dismount this weekend. I've already replaced it once ($27 I believe). Is anyone else having this issue or do y'all keep the bike shiney side up? Does anyone know of an aftermarket knob? At this rate my choke knob is becoming a $100/year 'consumable'.
  • kevin1209
Posted January 23, 2006 - 12:32 PM
Sounds like bad luck to me. What did your bike land on to poke in there two different times? That takes a lot of talent :thumbsup:
  • Indy_WR450
Posted January 23, 2006 - 12:33 PM
Never heard of that one? :bonk: The only thing that happens to mine is the detent out position wears over time and engine vibration can turn the choke off. :thumbsup:
  • WGP
Posted January 23, 2006 - 12:53 PM
Mine is broken on my 05 but still has a flap I can pull/push.
I thought it was from my Ascerbis Tank hitting it in a crash?
  • dbailey223
Posted January 23, 2006 - 01:13 PM
Never hurt the choke knob on any bike I've had
  • Koko Azuela
Posted January 23, 2006 - 04:20 PM
Nope, not braking, guess you just have bad luck on breaking that
  • clark4131
Posted January 23, 2006 - 07:04 PM
Yep, broke a piece off my choke, but it still works. I bought a back up and have it stashed for later...SC
  • mtrablue
Posted January 23, 2006 - 07:08 PM
i did it once. not sure what i hit or when. i can't figure out how i got something in there and didn't get speared. i was able to take it apart and straighten the shaft. peel the little sticker off and tap the shaft out of the knob. it'll all come apart from there. i drilled through the knob and shaft and put a cotter pin in when i put it back together. i didn't want the knob to come off in my hand. (bought a spare to be on the safe side)
  • John M62
Posted January 24, 2006 - 04:54 AM
I just bent mine, so I replaced it. I'm not sure how it happened. I was riding in very tight woods that day.
  • nurooi
Posted January 24, 2006 - 05:36 AM
Yip bent my double. Seems that if you take a dive off the bike over the right hand front, your boot will catch the knob / pull it out and bend it in half. Then when trying to straighten it, it snaps. I have ordered a new one but in the interrim just unscrew it and hold the spring and plunger out. Once the bike starts I screw it back in. Let it idle for awhile until the bike is warm and you will not need it again for the rest of your ride.
  • Joe_dirtbiker
Posted January 24, 2006 - 03:11 PM
Wow, thanks for all the response. Good to know I'm not the only one. The first bent knob I blamed on my buddy Adam for being a meathead when strapping down the bikes (guess I was wrong...). The second time I notice just when the knob got bent. Falling over the right side of the bike. I was starting to wonder if it was my boot that had bent the knob since I knew it wasn't anything I fell onto. Thanks for the confirmation nurooi.
I too modified the first bent choke knob. Tried to bend it back just before leaving for 5 Mile of Hell. It broke. I then put some grooves in the shaft with my dremel and used some safetywire to fashion a functional knob fascimilie.
5 MOH is highly recommended BTW, reference link:
http://motoutah.com/.../swell/srs2.php
my pic of the trailhead sign:
http://www.astrowitc...G_0154.JPG.html
