06 450F - Strange Vibrations
15 replies to this topic
  • MotoSenior
Posted January 22, 2006 - 07:31 PM
I was able to take my new 06 450 out this weekend to break it in (by the way, I love it). While taking a few mellow break-in laps, one of the chain adjusters loosened-up and the axle slipped. This caused the wheel to become misaligned and the chain to go really slack. I took the bike home and removed the rear wheel to inspect. Everything looked fine. I went back out today and noticed that when I decelerate, I "feel" a strange vibration. If I pull in the clutch it goes away. My gut feel is that it's coming from the engine. If so, I suspect that the counter-shaft bearing may be bad. Any ideas? Since it's brand new, I'm going to take it to the dealer.
Otherwise, the bike is GREAT! Feels very much like a 250F with more power. Well worth the wait.
  • dangwartz
Posted January 22, 2006 - 08:22 PM
If it's Yamaha's fault, you shouldn't have any problem since Yamaha has a 30-day warranty on their mx bikes. Let us know how it goes.
  • YZF831
Posted January 23, 2006 - 10:26 AM
Not to be cocky but did you give your bike a once over before you rode it or just left it the way you picked it up. I know you get a check list from your dealer as did I but I found so many loose bolts and half of them were not torqued correctly that it wasn't even funny. I would ask your dealer what to do but good luck getting them to understand your "vibration" because unless they completley understand I don't think they will just start ordering you parts under warrenty to fix this by trial and error. Again I don't meen to be rude but never trust anyone whose touched your bike without you checking it before you ride, even if it is brand new. I wish you the best. :thumbsup:
  • Reyndogg
Posted January 23, 2006 - 11:25 AM
I found tons of bolts at wrong torque specs - both WAY too tight and barely finger-tight....wouldnt hurt to go through your bike. Check the spokes, chain adjustment, etc too
  • DPW
Posted January 23, 2006 - 12:04 PM
The three bolts on my oil filter cover I think where tighter than my rear axle nut.
  • Ga426owner
Posted January 23, 2006 - 02:14 PM
Never ride a brand new bike before checking everything..................otherwise this will be you - :thumbsup:
  • Reyndogg
Posted January 23, 2006 - 02:45 PM
You're right, GA...I didnt even ride the stock chain or sprockets, front tire, etc, much less ride w/o going through it fully...
  • Shawn_Mc
Posted January 23, 2006 - 02:53 PM
Check the sprocket bolts. If they slipped, you could have damaged the hub already and once those holes are oblonged, the hubs life is limited at best.
  • YZF831
Posted January 23, 2006 - 04:01 PM
Man I hear you DPW. I just finished with my first oil change and those bolts were outrageously tight, I like how the manual says 7.2 ft. lbs...ha, I mean c'mon, make it simple people.
:thumbsup:
  • MotoSenior
Posted January 23, 2006 - 06:17 PM
Thanks for all the advice. Yes, I did a visual inspection, but didn't check torques prior to the break-in ride (lesson learned there). I did go through the entire bike after that ride, and yes I found some under-torqued nuts and bolts, but nothing about to fall off. The sprocket bolts are fine.
I'm going to take a hard look at the wheel bearings, the axle, and the counter-shaft before I take it to the dealer. I'd like to go in with a specific problem rather than a noise.
Thanks again for the feedback. I'll let you know what I find out.
  • Norman
Posted January 23, 2006 - 07:54 PM
Check the chain to make sure it isnt tweaked or bent causing it to not run straight. I had a masterlink break once and the chain came off, I put a new link in and it did what you are describing. I put a new chain on and no more problems.
  • ShiftMXer505
Posted January 23, 2006 - 08:02 PM
This don't have anything to do with your problem but check your airfilter to make sure it has oil on it. My 06 didn't have a drop of oil on it and thats when i also noticed how lose the number plate bolts were, so I went over everything with locktite. Also when my dad bought his 03 a few years ago he had a mouse nest in his airbox which also ate some of his airfilter which he was not very happy about that.
  • dangwartz
Posted January 23, 2006 - 08:12 PM
Norman. What made you decide on the 06 YZ450F? I see you are coming off of an 04 CRF450.
  • Norman
Posted January 24, 2006 - 04:35 AM
I had two 426's and went to the CRF when Yamaha went to a 4 speed. I race harescrambles and needed the 5 speed. I had 3 CRF's and loved them but I got tired of putting valves in them. I never touched my 426's and hope the new one will be as reliable. Also I think the YZ handles better in fast whooped out straights. :thumbsup:
  • Reyndogg
Posted January 24, 2006 - 10:15 AM
Shift, thats interesting... mine was over-oiled, so much that it had dripped in the airbox and i could sling it off like rain in the driveway
  • dangwartz
Posted January 30, 2006 - 10:50 PM
MotoSenior,
Been waiting patiently to see what you found out. Just got mine and I've been going over it. So far so good. Oil on filter seems a little light, though. Anybody check the head bolts after break-in? Is it necessary?
