jets for 93' 650L
2 replies to this topic
  • skoaljunkie
Posted January 22, 2006 - 04:02 PM
Hi,
I am working on a real fixer upper. I got the carb apart again, and the jets are a 55s and a 155. The bike is stock as far as I know and I don't plan on changing much, maybe a better airfilter and blocking the smog stuff. Are these the stock jets, should I think about upgading. (I'm not planning on high elevation, or racing, I just want it to run and start good.) Also how far out should that little screw on the bottom of the engine side throat be ( I think it is the mixture screw?).
Thanks TL
  • Wheels up
Posted January 22, 2006 - 04:21 PM
Do a search and you will find alot of info of the carb itself and how to max it out.
  • Wheels up
Posted January 22, 2006 - 04:32 PM
Install high flow aftermarket air filter (i.e. Uni,K&N)
re-jet carb; 55 pilot/165 main
Shim stock needle .024 (ish)
Drill vacuum slide holes to 5/32
Grind stopper tab off air/fuel mix screw and turn out 2 to 2 1/2 turns.
Thats mine.
You should have a 158 main and drill the slide. Play with you needle positions.
