bk MOD
3 replies to this topic
  • boxsterboy
Posted September 10, 2001 - 11:25 AM
I got everything for the BK mod last night and going to talkle it tonight. I do have one question. When the gas continues to spray after the throttle is let go, what happens to that gas? I've taken carbs apart many times and started to think about it. What I came up with is that the gas still makes it to the cylinder put isnt used efficental and thats what causes the boggieness (sp?). I wonder what kind of fuel gains are made? Has anyone tried seeing how long a tank lasts? I'd be interested to know.
01 WR426 Uncorked.
  • Stefe9999
Posted September 10, 2001 - 01:04 PM
Good point,
I was wondering if that unspent fuel is what causes backfiring. Think about it, blip the throttle quickly then let off, the pump is still squirting, so all that raw gas is still going somewhere. Maybe it could get through the throat somehow.
  • Hick
Posted September 10, 2001 - 02:36 PM
I dunno...
If you look at the way the pump operates releasing the throttle picks the rod back up off of the diaphragm, at which point the spring inside the pump will push the diaphragm back up, this will stop any additional fuel from being delivered and draw more fuel into the pump from the bowl.
To state it another way:
The arm that operates the pump is spring loaded, as the slide pulley rotates it allows the arm to push the rod and operate the pump, but when the pulley rotates back it will push the pump arm back into its starting position.
The popping at trailing throttle is almost always a lean idle circuit or leaky header.
  • DOC
Posted September 11, 2001 - 01:06 AM
Hick is spot on with his comments. Once you back off the throttle, the juice stops flowing.
