front fork air pressure????
5 replies to this topic
  • xr-jorger
Posted January 20, 2006 - 06:24 PM
is the air valve on top of the front forks on a 98 xr600 just to bleed off pressure, or should it be filled to a certain pressure? also the front end tends to botttom out on a long section of whoops, its set up fo 220lbs, is this a sign of bad forks, low air(if required), or need of new oil.....or should i just loose weight (since Im at that 220lbs limit :thumbsup: ) thanks all
  • AzMtnThumper
Posted January 20, 2006 - 09:23 PM
They are to bleed off pressure. Put your bike on a stand so the front tire is off the ground first. :thumbsup: If you are bottoming prematurely investigate the oil level and/or viscosity (since you mentioned the bike is set up (sprung) for your weight).
  • XR4DEZ
Posted January 20, 2006 - 09:41 PM
Tighten the compression 2 clicks and try it out.
  • nate992v
Posted January 21, 2006 - 08:05 AM
According to the owner's manual, they can have up to 15psi of pressure in them. They adjustment procedure in there.
  • dukeryder
Posted January 21, 2006 - 10:04 PM
I know on the L model it says 6 PSI max, and just use a Bike Pump to pump 'em up.
  • bigboredbiker
Posted January 22, 2006 - 03:49 AM
As far as I know, with the front wheel off the floor and the forks at full extension, the standard air pressure is 0psi. You can pump a bit more in to stiffen them up, but don't over pressure them...I would agree on 6 or 7 psi, 10 at absolute max if you want to the front forks to feel like they're seized. Don't forget that the stiffer the forks, the more bashing the rims/spokes and bearings have to take...don't blow your seals either!
  • 4 replies
Honda XR650L 2017
  • 0 reviews
  • 9 replies
  • 3 replies
  • 17 replies
