wheel swap with YZ / YZF??
11 replies to this topic
  • wedrivezs
Posted January 19, 2006 - 04:30 PM
I'm wanting a extra set of supermoto wheels.....
I've got a package lined up for $730.00 to my door for excel wheels (silver) custom spokes, and a front brake (320mm) kit. I need an extra set of wheels to tear apart for the hubs.....do the YZ / YZF wheels fit a '04 wr450?
Also, does that sound like a good deal? I still have to lace and true them up, but that's the easy part :thumbsup:
  • MTRSPORTDAN
Posted January 19, 2006 - 08:11 PM
The front hub from a YZ is different than the WR, but the rears are the same. The WR hub has the pic up for the odometer.
If that is without hubs it sounds a little steep to me.
  • SpeedBlitz
Posted January 20, 2006 - 05:52 AM
ok, I'll sum it up for you. Any YZ hub, 125, 250 250F 400 426 450, 1999-2004 will work. The only thing you will run into is that the rotor sizes changed a couple times on both front and back rotors. This will cause the caliper to either foul or not contact enough of the rotor. No problem, if you use the correct rotor. On the rear rim, 125's and 250's use a 1.85" rim rather than the 2.15" found on YZ 250's and 400 426 450's. On the WR series, the hub is also slotted to accept a speedo drive but will work on a YZ or a WR without the speedo drive with a YZ axle spacer in place. By the way I have personally tried a 2004 YZ250F front on my 1999 WR and it does fit.
fershy
Above is a quote from this thread:
http://www.thumperta...1&parentpage=13
  • ncmountainman
Posted January 20, 2006 - 06:38 AM
i've done it too,just need the yz spacers up front(actually just the right side) :thumbsup:
  • CycleWriter
Posted January 20, 2006 - 09:44 AM
Correct me if I'm wrong, but doesn't the WR speedo drive also serve as the hub seal on that side? Replacing it with the YZ spacer will leave the hub open to the elements, no? :bonk:
  • SpeedBlitz
Posted January 20, 2006 - 10:09 AM
Yes, the odo drive serves as a seal on the WR front wheel hub, but if you are installing a YZ hub/wheel, it will come with a seal on the hub.
  • CycleWriter
Posted January 20, 2006 - 10:30 AM
I understand that. My point is that simply swapping the WR odo drive for a YZ spacer will leave the wheel bearing vulnerable. As an aside, I removed the odo from my WR in favor of a TrailTech computer and YZ number plate. If you are doing this you must plug the hole where the cable entered the drive or it will get contaminated. I also removed the plastic drive gear inside the housing to prevent unnecessary drag and wear of the odo drive unit.
  • ncmountainman
Posted January 20, 2006 - 01:41 PM
ya uh, "WHEEL SWAP" with yz/wr?? i kinda meant you can't use your right side odo gear anymore and you need the yz spacer,but the stocker wr will work on the left. your right that you can't just replace the odo drive witrh a yz spacer. there are odo drive replacements available, BARNUM PRO makes one as does someone else i can't remember :thumbsup:
  • CycleWriter
Posted January 20, 2006 - 05:50 PM
I've been trying to get one of them odo eliminators from Barnum for almost a year. He keeps telling me he'll have some soon. I'm still waiting. :thumbsup: :bonk:
  • MTRSPORTDAN
Posted January 20, 2006 - 06:51 PM
I want one also but can't find it. I have a trail tech computer and want to get rid of that huge spacer.
  • ncmountainman
Posted January 20, 2006 - 09:00 PM
checked my notes,the other one is 4 strokes only-odo replacement/block off spacer, type 4.... pn/44-0583.... $26.95
1-818-765-5616 PST or google 4 strokes only :thumbsup:
  • SpeedBlitz
Posted January 23, 2006 - 06:22 AM
Cycle, I misinterpreted you statement when you referred to the "wheel bearing". I assumed you were referring to the actual wheel bearing and not the odo drive bearing. My assumption was same as NCMM, that is using the YZ wheel meant completely removing the odo hardware.
BTW, thanks for posting pics of your "TTR starter/kill swicth" setup. That is exactly what I'll be doing this spring!
