XR650R Thermostat
12 replies to this topic
  • motopsycho650
Posted January 18, 2006 - 10:24 AM
Just for fun, has anyone found an after market thermostat for the 650R that DOESN'T have to be modified?
I am using the NAPA #115 thermostat, which seems to work great. it just sucks you have to drill a hole, and buff off a few thousands of an inch off the top to get it to fit in the housing.
BTY, if anyone working at Honda reads this, FIX THE DAMN THERMOSTAT. The guide pin is too short, and it gets stuck open. Stop denying the problem and FIX IT!
  • scotty810
Posted January 18, 2006 - 04:10 PM
You try Summers Racing? I got mine from there a couple years ago and it didn't need to be modified.
  • jim1234
Posted January 18, 2006 - 06:02 PM
Summers is a sure bet!
  • Thumpmeister
Posted January 18, 2006 - 08:20 PM
SRC... Relatively cheap, and you know its gonna work...
  • Old_Man_Time
Posted January 18, 2006 - 09:25 PM
I didin't mind drilling the hole on the NAPA thermo. I did not have to buff mine to get it to fit. Just drilled the hole and it dropped right in place. :thumbsup:
  • mikekay
Posted January 18, 2006 - 10:13 PM
Hey--they fixed the countershaft seal....now if only they would fix:
.... the footpeg that falls off, and the carb that has the float bowl set to high, and the airfilter that leaks, and the hubs that crack, and the rims that dent, and the front disc thats to small, and the tank thats way to small, and the dip stick that catches, and sub frame thats bent.
  • TimBrp
Posted January 19, 2006 - 04:12 AM
I'd have to say you nailed every flaw down to a "T" Mike. However, all the other areas that shine negate all of those IMO. Should've honda addressed these issues, hell yeah. But they never will now.
  • motopsycho650
Posted January 19, 2006 - 07:57 AM
That's not all the issues either. I had a waterpump seal go bad, and the lower bolt hole for the chain guard cracked. (The engine casing cracked). Both of these were fixed under warrenty.
I've never had an issue with the stock air filter leaking. When I was using it, I used the sealer that came with a Honda air filter kit. Now I use a K&N. No issues there, just make sure you use a lot of waterproof grease around the seal.
Yamaha has the right idea though, renthal bars, excel wheels & hubs, and the 06 WR's are rummored to come with a trail tech computer. Too bad Yamaha doesn't make a big thumper. (I do not consiter that short stroke 450 to be a thumper)
  • motopsycho650
Posted January 19, 2006 - 12:14 PM
I didn't know about the SRC thermo. If I need to do another thermostat, I'll probibly try that. I used the Napa one from a recomendation from the pig pen xr650r.us.
I was a bit worried about modifying the stat, but it does work. If you got one that didn't need to be buffed don't, you're lucky. I was afraid I'de make the top of the stat weak.
But I will say, the napa stat works just fine so far. and it was onlt 4.99, compared to 16.99 for the SRC. The extra 11 bucks would be worth it just for peice of mind.
  • STENY
Posted January 19, 2006 - 02:53 PM
Take it out and throw it away. :thumbsup: Unless you are cow trailing every ride. Just one more thing to fail away from your truck. Remember to change out to the Kawie cap though. :bonk: Steny
  • motopsycho650
Posted January 19, 2006 - 04:50 PM
I can't do that. I live in colorado, and sometimes am riding in 30-40 degree weather. Without the thermostat, or having the stock one stuck open, the bike wasn't reaching temp. NOT GOOD!!!
  • XR4DEZ
Posted January 19, 2006 - 07:24 PM
You can toss it ,if you ride in a warmer climate.
  • Potts228
Posted January 20, 2006 - 10:45 AM
LOL!!! But fixing these things gives us something to do!!! :thumbsup:
