yz 426 front sprocket removal
10 replies to this topic
  • Code
Posted January 16, 2006 - 07:39 PM
Any tricks to get this sucker to break free...Wife standing on rear brake...i lifting the stinking bike and wife off the ground trying to get the counterchaft nut to loosen up....
Anyone been there, done that? Sure could use the help...I do not want to Round off the nut.......
Thanks...
:applause:
  • CRFThumper
Posted January 17, 2006 - 04:56 AM
Impact!!! Thats a big nut and hold a lot of tourqe.The sharp blows help a lot.
  • SureBlue
Posted January 17, 2006 - 11:56 AM
And put the gears in neutral, you don't want to break anything.
  • SSpeeDEMONSS
Posted January 17, 2006 - 06:12 PM
definately either an impact gun or a breaker bar with a hammer. CRFthumper has it correct. :thumbsup:
  • INJURY_69
Posted January 17, 2006 - 08:01 PM
Have a question? Use our Search feature (top right) before asking. Our archives are huge and most likely it's already been discussed at length.
In this case you didn't even have to search but just glance at the latest threads.
  • rockieman
Posted January 17, 2006 - 08:47 PM
I had a tough time getting mine off of my WR this winter. Impact would not break it loose. I finally got it off with a bf pair of channel locks and a breaker bar.
Try some PB BLaster on the nut prior to....
  • tacoma426
Posted January 17, 2006 - 10:06 PM
I had to use a Impact as well. Good Luck
  • Yak
Posted January 17, 2006 - 10:15 PM
Forget trying to hold the brake or put it in gear... I put a hammer handle through the spokes on top of the swingarm. Put it right up against the nipples. There is no way on earth you will be able to generate enough force to do any damage. Works every time. Repeat for installation, but this time under the swingarm... obviously.
Note: Assuming you still have the chain on.
  • Fizz
Posted January 18, 2006 - 08:05 AM
i do that every time, works perfect .... :thumbsup:
  • bxrjim
Posted January 18, 2006 - 02:05 PM
When doing work like this I was taught by the old schoolers. I work by myself so no ones around to hold my brake. Take a piece of 3/8 soft nylon rope and tie a knot in it at the end. Remove your spark plug and slide the knot into the cylinder and carefully raise the piston till it stops. Take the sprocket off or the flywheel what ever your doing and then to tighten back up reverse the process. I'm curious as to what you think about this method, so do tell.
  • Code
Posted January 18, 2006 - 04:36 PM
Good tips....thanks Guys....went without a hitch :thumbsup:... New chain and sprockets...just waiting to get dirty :bonk:~
  • On January 15, 2017
  • 10 replies
  • Hot  47 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • Hot  38 replies
