Special tool for rear shock removal?
3 replies to this topic
  • dbailey223
Posted January 14, 2006 - 11:31 PM
Is there a special tool for moving the lock ring and other ring on the rear shock when loosening them for removal of the shock? I thought I read about hitting them with a hammer and scre driver to loosen them up. That worked fine on the lock nuck, but it seems like a lot of beating to turn the lower one until the tension is removed. I don't want to ding it up if I should be using a special tool, etc.
  • Matty05
Posted January 15, 2006 - 02:10 AM
Hammer and big screwdriver fine. You can buy spring compressor tool at auto shop
that makes job a bit easier only when shock is out of bike.
  • AUS_WR450
Posted January 15, 2006 - 02:52 AM
you can sometimes just grab the spring tightly by hand and turn it. If you are lucky. the ring turns with it
  • tcmII
Posted January 15, 2006 - 07:12 PM
First, go to Sears and get a nice long punch. It will work much better and you won't get hurt. Screw drivers, especially those with plastic or resin handles, should never be hit with a hammer.
This will work on the upper and lower nut with the shock on the bike.
Second, if you want to turn the nut with the shock off you can get a cheap spanner wrench or a large channel lock. This will make it much easier to turn the nut.
