How to Bleed Front Brake - XR650R?
13 replies to this topic
  • DualSport650
Posted January 10, 2006 - 08:20 PM
All the sudden front brake doesn't work. I pull the lever back all the way to the handlebar and NO front brakes! I gotta get it fixed so I can ride!
I have no manual on hand, so what's the filling/bleeding procedure?
I'll give it a whirl, let me know if I've got it right...
1) Open reservior at the lever
2) Fill with brake fluid (DOT 5?)
3) Close reservior / Tighten screws
4) Open little valve down at the caliper
5) Squeeze brake lever until all air is expelled
6) Close little valve down at the caliper
7) Test the brake
8) RIDE!
:bonk:
How'd I do for just wingin' it? :applause:
  • BWB63
Posted January 10, 2006 - 08:39 PM
You need to press the brake lever "Open little valve down at the caliper" letting the air out, while the lever is still pressed in, close the " little valve down at the caliper" Then let the brake lever out. Do this till no-more air comes out. It is much easier with a brake bleader tube. You need to keep the reservior close to full while you do this. The way you did it you pumped more air into the caliper.
  • frankstr
Posted January 10, 2006 - 08:47 PM
I use a vacum pump, Much easier and faster....TMHO... :applause:
  • Old_Man_Time
Posted January 10, 2006 - 08:59 PM
Yep the vacum pump is the easiest. My honda shop lets me borrow their vacum pump and I finish the job in nothing flat. Nice hard brakes everytime. :bonk: :cry:
  • DualSport650
Posted January 10, 2006 - 09:39 PM
Easy!
I don't have a vacuum pump handy so I'll use Bruce's technique. :applause:
  • targetdrone
Posted January 10, 2006 - 09:47 PM
Don't put on the resevoir cap until you are done. Grab and hold the lever. Loosen bleed bolt, tighten bleed bolt. Release lever. Repeat as much as needed until your brake has the proper feel. Don't let the fluid level in the resevoir get low enough to allow the master cylinder to suck air. Refill to proper level and replace cap.
Make sure you put a small hose, preferably clear on the bleed bolt and have it drain into a catch can while you do this. Brake fluid is nasty to many surfaces.
  • DualSport650
Posted January 10, 2006 - 09:51 PM
Roger wilco targetdrone. :applause:
I've actually done this procedure, but it was YEARS AGO when I had my XR600. I think I'll git me some brake fluid tomorrow and fixer 'er up! :bonk:
  • targetdrone
Posted January 10, 2006 - 10:02 PM
A quick addendum: If the fluid coming out looks nasty, (another reason to use a clear hose) keep bleeding until it comes out looking clear, or at least reletively non-contaminated.
  • Max Power
Posted January 10, 2006 - 10:09 PM
7) Test the brake
8) RIDE!
:bonk:
Pure Genius. :cry:
  • DualSport650
Posted January 10, 2006 - 11:22 PM
My momma didn't raise no dummies. :applause:
Actually she did because I just stripped out the first damn screw I tried to loosen. One of the reservior cap screws. :cry:
Now I gotta go to the friggin' hardware store and get one of those stripped bolt taker outer tools. :bonk:
  • TimBrp
Posted January 11, 2006 - 03:49 AM
An easy out is what you need. I use the vacuum pump. Works great. Try filling and bleeding steel lines the "old" way. Not gonna happen.
  • DualSport650
Posted January 11, 2006 - 09:40 AM
OK, I'm game.
Where do I get a "vacuum pump"? The local auto parts store?
  • oldturtle
Posted January 11, 2006 - 10:12 AM
I am sure the brakes can use all new fluid as suggested. However be sure and check that the adjustment screw on lever has not loosened up and is causing the problem. This would be first thing to check. :applause: Just don't ask how I know this.
  • DualSport650
Posted January 11, 2006 - 10:30 AM
Yeah, that would suck.
My adjuster is all the way IN. Time for some brake work!
  • 17 replies
  • Hot  60 replies
  • Hot  29 replies
  • Hot  186 replies
