Good Fix for the 2001 426 forks?
11 replies to this topic
  • sldietz
Posted January 10, 2006 - 02:22 PM
I weigh around 225 in full gear. Bottoming is a problem. Anyone using the Race Tech Type 2 Gold Valve set up?
Thanks.
  • FOX426
Posted January 10, 2006 - 04:57 PM
Go with heavier springs first if you have not already.
  • Satch0922
Posted January 10, 2006 - 05:19 PM
heavier springs and new oil first. Set the oil level at 100mm and I recommend 7wt oil.
Without the correct springs a revalve is pointless.
  • sirthumpalot
Posted January 10, 2006 - 07:01 PM
definitely raise the fork oil level. I think min is 80mm.
  • odlaw19
Posted January 10, 2006 - 08:46 PM
On the topic of 426 forks...
I am about 135lb and have never really setup the front end on my bike. I have set the sag and played around with the rebound on the rear.
What would people recommend for setting my front end up? I mainly ride trail/woods and some dune riding. Most of the surfaces i ride on are sandy.
As far as i know, the current setup is stock.
Thanks.
  • 642MX
Posted January 10, 2006 - 08:57 PM
Thanks.
You need stiffer springs. I think mine are .49 on the front and a 5.8 on the rear. I'm 6'4" and 230 lbs.
  • 642MX
Posted January 10, 2006 - 09:00 PM
Thanks.
426's where set up for 175 lb. riders. You need to buy the correct springs too. :applause:
  • Geezerx
Posted January 10, 2006 - 09:04 PM
check the Race Tech site. They have a spring chart for weight and type of riding.
  • odlaw19
Posted January 11, 2006 - 04:48 AM
Thanks 642MX.....
I might just hook into some pies and cakes..... or go to the gym!
  • sldietz
Posted January 11, 2006 - 09:59 AM
So who do you recommend? Ive talked with Race Tech and Factory Connection.
Is it like apples to apples here?
Posted January 11, 2006 - 10:21 AM
Did you get my PM? The springs I have are about right according to Race Tech's selection page. They call for .475 on the front, and mine are .48. They call for a 5.6+ on the back, and mine is a 5.8, which is not too far off.
  • mattskn
Posted January 11, 2006 - 12:39 PM
Im 6'3 235 with gear I put in a set of race tech .46kg in and 120cc of 5wt and it stoped all of the bottoming out really stiffend the front Now I need to get the matching spring for the back.
  • Hot  113 replies
  • Hot  30 replies
  • 10 replies
