Installing Sprockets, chain and rear tire
22 replies to this topic
  • MathProf
Posted January 12, 2006 - 06:13 PM
If I were you, I'd replace the sprocket bolts with new nuts and bolts, and loctite them.
I have replaced several rear sprockets and the re-used bolts never stay tight.
They can loosen and ruin your hub before you know it.
As far as tubes go, I find an old tube, split the old tube on the rim-facing side of the tube all the way around, then put the new tube inside the old one. A little baby powder will let the inside tube slip inside the outer tube and reduce pinch flats.
  • marcusmoberg
Posted January 12, 2006 - 08:47 PM
You mean now I have to order new freakin' sprocket bolts!!!! :applause: :bonk:
  • marcusmoberg
Posted January 12, 2006 - 08:49 PM
You mean now I have to order new freakin' sprocket bolts!!!! :bonk: :cry:
I think I will just use the old ones instead! :applause:
It seems like with the BLUE LOCTITE on them they will stay tight!!!! :cry:
