stripped bolt
7 replies to this topic
  • moach1
Posted January 07, 2006 - 09:25 PM
my frame oil bolt is stripped. not the bolt but the frame. it will tighten up but not much more than finger tight. should i use a helicoil or just use a drop of thread locker? any help is appreciated.
  • WildRide
Posted January 07, 2006 - 11:18 PM
Have you chased the threads with a tap? Sometimes combined with a fresh bolt and thread locker you can get decent holding power.
  • xr_man
Posted January 08, 2006 - 03:07 AM
there is enough metal to tap to the next size up.....why take a chance with anything less than a new thread ???
  • kevin1209
Posted January 08, 2006 - 05:31 AM
I agree. :applause: Just drill and tap the hole to the next larger size. If nothing else, it will give you peace of mind on your next ride. :bonk:
  • moach1
Posted January 08, 2006 - 02:08 PM
ya i think i will go up one size. thanks for the input :applause:
  • Gadsen
Posted January 08, 2006 - 07:53 PM
Try going one size up. Keep the sizes in "even numbers", if you tap it to those goofy odd numbers, ( I hope you will keep it metric) you may never find a drain plug for it. Also, a heli-coil would work, but even better would be a thread insert. Do locktite the insert of helicoil in. You can buy a helicoil kits for about $45. It will come with the tap, coils,. insert tool and the tap will tell you which drill size to use.
  • simch
Posted January 11, 2006 - 07:50 PM
or just weld a new nut on the front of the stripped one. I did it with my engine plate captive bolts, it worked a treat! You have good access so you will get a nice weld.
You can keep stripping them and doing this, until the bolt catches on the front tyre!!
  • moach1
Posted January 11, 2006 - 08:03 PM
thats a good idea, never thought about that.
