06 yz450f oil change question
2 replies to this topic
  • yzf_guy
Posted January 07, 2006 - 05:57 PM
So the manual says if you are doing a periodic oil change then you put in 1 quart, if you do a oil change with filter change then you put in 1.06 quarts then it say with a total amount of 1.27 quarts. My question is if you do a change with filter do you put in 1.06 or 1.27 quarts. I put 1.27 quarts and it was right at the top line on the dipstick, I also let it run for a couple of minutes like the manual says before I checked it.
  • tom_dappert
Posted January 08, 2006 - 06:28 AM
I just use the quantities stated in the manual as a guideline as it depends on how well you drain the oil from the engine, the filter housing or whether you've just done a complete tear down. You did good.
  • Lizard 1
Posted January 08, 2006 - 07:28 AM
Uh, unless you do a complete tear down, you don't need to worry about the 1.27 amount. In other words, all the oil in the motor that you'd remove in a tear down (Cleaning and eveything) would add another .21 quarts total maximum amount.
If you put in 1.27 quarts, it's too much for just an oil and filter change...
  • 10 replies
  • 9 replies
  • Hot  47 replies
  • Hot  36 replies
