spokes?
10 replies to this topic
  • jjcmx05
Posted January 07, 2006 - 03:52 PM
Any one know if yzf and crf 450 rear spokes the same??? :applause:
  • kawirider
Posted January 07, 2006 - 05:58 PM
Are you trying to use some CRF spokes or something?
  • Hellbilly
Posted January 07, 2006 - 08:51 PM
It isn`t likely that they are the same but you could check part numbers in the RTT store on aftermarket spokes to see if they are the same.
  • 450_rider
Posted January 07, 2006 - 10:51 PM
I think i remember reading on TT that they could both be used. Some guy needed one spoke and someone said he could use one off his crf.
  • fowler175
Posted January 08, 2006 - 07:39 AM
I believe the deal is that you can't buy just one Yamaha spoke (unless your dealer will do it), but you CAN buy a single for honda. I too would like to know if they are the same.
  • Matt96xr6
Posted January 08, 2006 - 08:33 AM
Honda and Kawi sell the spokes and nipples as singles.
Really if you have the connection at the dealer the set is only like 40-50 bucks. Spokes and nipples.
I have almost a few times bought a set so that I can have some spares and then piece out the rest for situations like this. But most likely if you have one, there are more that are problems.
  • RCannon
Posted January 08, 2006 - 11:03 AM
I cannot answer on the rear, but the fronts are the same on all full sized bikes since about 96.
  • Matt96xr6
Posted January 08, 2006 - 03:17 PM
Well the spokes may work, but will be a bit long or short. Yamaha made a wider front hub in 02 and use a longer spoke set.
  • jjcmx05
Posted January 11, 2006 - 12:00 PM
ty all was gone for a bit... I have a honda and a yamaha.. And i have set of OEM yamaha spokes on hand.. The honda got a few spokes riped out.. looks like i am going to have to try it!!!
  • RCannon
Posted January 11, 2006 - 12:51 PM
Here is the odd thing. The white bros spoke set (front) I just bought listed as being ok for ALL CR, YZ's, YZF's and RM's. Perhaps the longer length was not much different.
Not that I am complaining. This makes the wheel building process much easier and cheaper!
  • 642MX
Posted January 11, 2006 - 04:50 PM
They are the same spoke on the rear. The CRF and YZF interchange perfectly.
