can't solve the problem!!
30 replies to this topic
  • mxyves
Posted January 07, 2006 - 08:39 AM
Help me out here...
my wr426f doesn't run smooth. on 1/4 throttle the engine starts to stutter. If i stay in this revelationrange it keeps stuttering. When in open the throttle wider, it stops to stutter and runs well. We've tried everything to solve the problem: new sparkplugs, cleaning the carb, needle adjust, jetting adjust, cleaning all electrial conections. Nothing seems to help.
Does this sound fammiliar to anybody?
  • foxkid
Posted January 07, 2006 - 10:27 AM
Hello mxyves,
Have you tried an other CDI? Or could it be the bobine-coil?
Succes,
Foxkid
  • byggd
Posted January 07, 2006 - 10:56 AM
My 02 426 was doing the same thing and I kept thinking it was jetting. Then JD said to try unplugging the TPS. I did and it smoothed right out for constant running but I still think it runs better when it's connected when I'm riding trails.
  • SJMC_DON
Posted January 07, 2006 - 02:51 PM
Yeah my suggestion would be to try unplugging the TPS and see if it helps, then go from there. The inherent mid range sputtering issues with the TPS are not that bad and only become a nuisance while cruising down a road or something at a constant low to mid RPM.
Good Luck :applause:
  • foxkid
Posted January 08, 2006 - 06:50 AM
What is a TPS? Is that famous grey wire?
  • byggd
Posted January 08, 2006 - 09:24 AM
TPS = Throttle position sensor. Look on the left side of the carb and you will see an electrical unit held on by two screws. Follow the wires coming form it for a couple of inches and you will find a connector.
  • Matty05
Posted January 09, 2006 - 03:27 AM
That is a jetting problem pure and simple.
You are rich on the needle. Drop it one clip and check. If too lean then,
try adding a tiny washer to shim the needle up 1/2 a clip.
  • MotoGoalie
Posted January 09, 2006 - 08:07 AM
I agree. Sounds rich.
  • byggd
Posted January 09, 2006 - 09:34 AM
It might be but it can't hurt to try disconnecting the TPS and see if it helps. I jetted mine three times and the constant throttle miss wouldn't go away so i was getting :applause: Disconnected the TPS and I loved my bike again :bonk:
  • mxyves
Posted January 10, 2006 - 01:33 PM
Thanks for the updates!
I'll disconnect the TPS-sensor first (easy job) and see what the bike does. I played too much already with the carb and it doesn't help one bit sofar.
But what if it helps; losing the TPS-signals. No problem to keep it disconnected?
  • mxyves
Posted January 10, 2006 - 01:57 PM
forget my last question. Great tool this "search" button....
I'll try it out when it's day again here.
  • Matty05
Posted January 10, 2006 - 02:48 PM
Does changing the needle position make any difference at all? If it stays EXACTLY the same, I would be checking for air leaks. Measure your float height too.
  • Rider1958
Posted January 10, 2006 - 03:01 PM
I had what sounds like the exact same problem. I fixed it by doing exactly what Matty05 said to do - dropped the needle one notch to lean it. Cleared it right up.
  • David37
Posted January 10, 2006 - 09:08 PM
I would try a leaner pilot jet and see if that clears up your stutter, you may have to go two sizes leaner to clear up your problem.
  • mxyves
Posted January 11, 2006 - 02:57 PM
Air leaks? Where could I find an air leak on the bike?
  • Matty05
Posted January 11, 2006 - 03:24 PM
The boots around the carby come to mind, exhaust leaks tend to give some good cracking.
Start your bike up and suss out around the carby. Inspect rubber boots for cracks, airbox boot too. A gentle spray around with soapy water is a good way to find leaks.
Is the stuttering a popping/crackling sound or does the bike feel like it is running real rough/stumbling/cutting out?
I still say drop the needle one or two clips.
  • mxyves
Posted January 12, 2006 - 02:40 PM
I "lost" the TPS signal but it didn't solve my stuttering-problem unfortunately.
[COLOR=Red]qoute "Is the stuttering a popping/crackling sound or does the bike feel like it is running real rough/stumbling/cutting out?"[/COLOR]
When I pull the throttle 1/4th, it smoothly comes up to the max rev's for a quarter pulled throttle. When I slowly turn it then to 1/2 full throttle it starts to fall away like I would be pressing the "turn-off" button several times within a few seconds.
The clip on the needle is now on position 3, which is half way up I think. Should I lower the needle and place the clip on the highest clip-position as possible to feel the effect?
  • Matty05
Posted January 12, 2006 - 03:03 PM
You are definately rich on the needle, just lower the needle 1 clip position!
You might need to get the next leaner needle from Yamaha. Either that or
A JD jetting kit. Are you going the right way when you change the clip position?
Hold the needle how it sits in the carb (pointy end down, clip up top), top clip is the leanest clip position, #1.
Don't worry about air leaks, it doesn't sound like you have any.
  • dbailey223
Posted January 12, 2006 - 03:12 PM
Get the JD kit. Well worth it.
  • mxyves
Posted January 12, 2006 - 03:57 PM
Thanks for your update. I'm reprosition the needle.
About the leaner needle; leaner like in less thick? What does it do more or less and what effect does it have anyway?(sorry I don't understand)
