For the attention of James Dean
17 replies to this topic
  • Brett_Green
Posted September 06, 2001 - 06:03 AM
James
Been looking through a few old posts, and saw your recommendation for carb settings.
EKN#4
#170 main (may want to try #165)
#48 pilot
#100 air
1 turn out on pilot screw
Are these settings suitable for a '99 WR ?
I run YZ timing, airbox cover removed; and swap between a CRD 92db pipe (for quiet trail riding) and a 99' YZ pipe for flat-out crossing.
Your advise would be gratefully appreciated.
Cheers
  • James_Dean
Posted September 06, 2001 - 06:26 AM
Yes, the setting is also recommended for the '98/'99WR or YZ. The bike will probably run better/cleaner with EKN#3 with a quiet exhaust or at high altitudes. Depends on riding style and preference.
  • Terry_in_Reno
Posted September 06, 2001 - 08:06 AM
James,
My 00 WR, grey wire mod, yz timed just got a new FMF power core IV and power bomb header. I have ordered both the EKN and ELN needles because of a hesitation at 0~1/8 when I go to WOT. I assumed that since these two needles are just 1/2 clip difference either would work, but to fine tune I could switch between them. Is this on track?
BTW, I'm at 4500 and ride 3000 to 9000.
Terry
  • Terry_in_Reno
Posted September 06, 2001 - 08:46 AM
James, I am also getting ready to do the BK mod tonight.
  • Brett_Green
Posted September 06, 2001 - 10:12 AM
James
Thanks very much. I'll give them a try over the weekend and report back. Do you have a Yamaha part number for the needle?
By the way, whats the 'BK mod'???
Thanks again
  • Terry_in_Reno
Posted September 06, 2001 - 10:42 AM
Brett, The BK mod is just adding a screw to the accellerator pump to make the timing adjustable. You need to tap a screw onto the pump stop. Do a search on BK and find what you need to know.
  • WRFUN
Posted September 06, 2001 - 11:06 AM
James Dean,
Do you have the part#'s for your jetting suggestions. I will be going to YZ timing next. Thanks for your expertise.
Pete
99 WR400
Stock pipe - cork out, throttle stop cut, air box lid removed
[This message has been edited by WRFUN (edited September 07, 2001).]
  • Terry_in_Reno
Posted September 07, 2001 - 08:28 AM
James,
I did the BK mod last night and the bog at 1/8 throttle got more noticable. I have stock jetting with the needle #4 possition. I'm at 4500, so I expected the altitude to compensate for the lean jetting. I am still waiting on the EKN and ELN jets. I have tried setting the fuel screw to 2 3/4 to 3 turns, as per FMF web site, but this was for YZ's and I am wondering if the different needle could be the cause. I thought this was acting rich on the bottom, so I have also tried the fuel screw at 1 1/2, and as far down as 1/2 turn out. I'm not really see any effect here. I the PJ just that far off.
I am about ready to put the needle back to #3 and see if the altitude was more of a factor than I expected.
Terry
  • James_Dean
Posted September 07, 2001 - 10:25 AM
Terry, try the stock DRS in clip #3 and with a stock #42 pilot turn the pilot screw out to 3-4 turns from seated. A #45 at 1 3/4-2 1/4 turns or a #48 at 3/4-1 1/4. Set the idle up to a faster speed. There is still going to be a limit to wicking the throttle open and bogging because this is a 4-stroke without a CV carb.
Part numbers:
OBELN - 5NL-14916-EN (YZ250F option)
OBELP - 5NL-14916-EP
OBEKN - 5JG-14916-EN ('00YZ426 option)
OBEKP - 5JG-14916-EP
OCEMN - Call Sudco, Keihin brass needle
OCEMP - Call Sudco, Keihin brass needle
The EMN, ELN, EKN are all identical except 1/2 clip difference in taper start. (EMN#5 = ELN#4.5 = EKN#4) Same goes for EMP, ELP, EKP.
[This message has been edited by James Dean (edited September 07, 2001).]
  • Terry_in_Reno
Posted September 07, 2001 - 11:55 AM
James,
I got the 5JG-14916-EN in today and it is an OBEVN needle will this still work or am I looking for another.
Also, I picked up #45, #48 PJ's and 170, 175, 180, 185 mains. I had the screw out three and didn't notice the problem getting better. Come to think of it I didn't have the bog with the uncorked stock pipe, and it ripped with the WR timing, except for the low ceiling.
Any last comments. I'll dink with it this weekend, but I have a race to run so I don't know how much.
Terry
  • Taffy
Posted September 07, 2001 - 12:10 PM
imagine the EKN needle on the 4th and middle clip ok?
for your needle to be in the same positin it must be dropped five clip positions. and yet you only have three above or below. the clip positions rise so that the needle drops, ok?
in other words this needle is, sadly, redundant.
Taffy
  • Terry_in_Reno
Posted September 07, 2001 - 12:15 PM
Thanks, just as I suspected.
Is there a way to get the correct number for the EVN or ELN needles.
  • James_Dean
Posted September 07, 2001 - 02:02 PM
Terry, did you get the ELN? It will work just as well as EKN.
Did you get the package with the part number and recheck the needle code? If it is as you have said then Yamaha has suddenly started to mix their bins of parts. 5BE-14916-E_ was EV_ needles and 5JG-14916-E_ was EK_ needles.
  • Terry_in_Reno
Posted September 07, 2001 - 02:13 PM
No, the other part didn't arrive. The part number on the bag was the correct one, that is what I had them check against the order.
Hold the phone, I just looked at the labels, yes two labels, one from Yamaha and one from the dealer. The dealer label has OBEVN, but when I look at Yamaha they don't call out the model #. Sooo I am looking on the needle and it is stamped OBEKN, looks like I'm back in business. MY BAD!!
I'll try this tonight, and the #45, 175 combination to see how it goes.
Thanks, I'd have skipped trying the needle.
Dealer has the wrong description, but Yamaha package the right part.
  • Taffy
Posted September 07, 2001 - 10:06 PM
ohhhhh yes!!!!
yamaha just llluuurrrvv taking you all the way to the wire!
glad you opened the package. of course you wouldn't be the first to slag the dealer, send it back with an irritated letter and ...
find that you'd been given the correct PART!
Taffy
  • WRFUN
Posted September 09, 2001 - 06:06 PM
James Dean,
Thanks for the part #'s. So off to the dealer to give them more of my money. Thanks for the time.
Taffy,
Thanks for clearing up the confusion on needles and what they mean... I'm new but reading and learning. Thanks for your time aswell.
Pete :)
  • Terry_in_Reno
Posted September 10, 2001 - 09:07 PM
James,
Thanks for the assistance. I got the jets in Friday night, but had to drive so I didn't get any testing done until Sat.
The needle is spot on. I got #45, #48 PJ's to adjust the pilot circuit, but the #45 was the wrong form factor. The #48 was just too large. I brought is all the way down to 1/4 turn out and it still has a burble 1/8 throttle. I'll replace the #45 and try it, I'm pretty sure that will finish the little bit of bottom burble.
Again, thanks for all the assistance. It really came through.
Terry
  • James_Dean
Posted September 10, 2001 - 10:37 AM
Terry,
Did you also get the #100 pilot air jet? This was to compliment the 48 pilot jet.
