timing/jetting question
1 reply to this topic
  • mdek
Posted September 06, 2001 - 03:40 AM
I have a 2000 wr400 which is wr timed and has an fmf powercore 4 S A. I am very happy with the jetting. If I yz time it will I have to monkey around with the jetting again?
  • Terry_in_Reno
Posted September 06, 2001 - 09:02 PM
I did the YZ timing before I added the FMF power core IV and power bomb header. without changing the jetting the timing moved the power up in the curve. When I added the pipe I ended up with a hesitation at 0~1/8 throttle. I have turned my pilot jet air screw out to 2 3/4 turns out and dropped the clip to #4 possition and eliminated 90% of the problem. Now I have a needle on order and the BK mod to hopefully take care of the last 10%.
I was very disappointed with the change to YZ timing until I started making the other changes. Since you already have the pipe in place, I would say it would be easy and cheap to make the change.
Just my 2 cents.
