Stripped (overtightened) bolt on radiator shroud
2 replies to this topic
  • SkyRaider
Posted January 04, 2006 - 01:52 PM
I was tightening one of the bolts on the radiator shroud, and I guess I overtightened it. It will turn, but not come out, so I guess the metal part is spinning in the gas tank wall.
Has anyone else done this? What is the best course of action?
  • byggd
Posted January 04, 2006 - 03:17 PM
Try prying slightly outward while you loosen the screw. Hopefully it will unscrew and then you can glue the wellnut back into place.
  • drewpeacock
Posted January 04, 2006 - 04:31 PM
I had the same thing happen on a 426 and never could get it off. When I got the 450 I put anti-sieze on the shroud screws right away in hopes to prevent that from happening again.
