Best USD forks for SM XR650L conversion
14 replies to this topic
  • TREADMARKS
Posted January 04, 2006 - 10:53 AM
Marzocchi shiver MX, Showa or revalved stock CRF 450?
  • mgs781
Posted January 04, 2006 - 11:38 AM
Stock CRF forks are Showa.
Any of your choices are going to reqiure alot of work.
The stock XR stearing stem is smaller than the CRFs. You will need to make a custom stem or make bushings to use the stock XR stem in the new triples. You will also need to make new steering stops for the CRF triples.
I used stock CRF triples and made bushings to use the XR stem. This was all press fit and require hours of machincing to make the bushing correct. I welded a extension onto the XR steering stop to work with the CRF triples.
I used 45mm Marzoochi forks.
Kubiak has stated that older CR250 forks are a straight bolt on with no mods. I think that is what he runs currently. Unless you have the resources, this would be the way to go.
MGS
  • TREADMARKS
Posted January 04, 2006 - 01:38 PM
Good info mgs. :applause:
Looks like I'm gonna be pretty busy. :cry:
You would think someone would make some conversion triples? :bonk:
What is everyone else using, cause I sure see alot of them? :cry:
  • khelton
Posted January 04, 2006 - 02:40 PM
You see a lotta "L's" with USD forks ?
  • mgs781
Posted January 04, 2006 - 03:29 PM
Mine is the only one I have seen.
  • lhark
Posted January 04, 2006 - 04:39 PM
Looks like you're running into the "L" model syndrome I did, when I built my '01. It was a good thing I had an XR600R for a number of years, and recognized some of the similarities between the frames, exhaust, etc.
I ended building a few things, or modifying 600 bits to work on the 650. I can't imagine that there aren't more of us out there looking for simple things, like aftermarket side panels, or even bodywork kits to re-work the look of their bikes.
As it is, the thing turned out great....I'll be posting a photo in that section one of these days.
  • rmhrc630
Posted January 04, 2006 - 05:49 PM
I agree
It's great fun looking at the similiarities between the 650L and 600R.
have just bought the entire left hand side engine case/starter motor etc and intend to fit them up to my 600R. They bolt right on.
Man I am going to have the only proper e start 600R going and I'm excited!!!!
  • lhark
Posted January 05, 2006 - 04:42 PM
I picked up an '87 XR600 for grins...and thought about the same thing. I never minded kicking the '86 I had, until I got the '01 650L...
Good luck with it.
  • dukeryder
Posted March 04, 2006 - 06:25 PM
MGS
Any idea what years??? Pre 2000, pre 95, pre 90? Thanks
I'm seriously considering this mod.
  • TREADMARKS
Posted March 05, 2006 - 05:05 AM
I am not sure about the straight bolt on part as there is a huge difference in the tube diameter.
I just installed mine this weekend-Marzucci and billet applied trees. Pretty simple once you get everything off and can start taking some measurements.
Heck, I am spending more time sorting out the electrical than I spend on the USD conversion. :thumbsup:
  • mgs781
Posted March 05, 2006 - 05:36 AM
[quote name='TREADMARKS']I am not sure about the straight bolt on part as there is a huge difference in the tube diameter.
QUOTE]
A complete front end (triples, forks, wheel) will bolt onto the XRL from early CRs (the ones with steel frames).
MGS
  • weskc35k
Posted March 05, 2006 - 05:39 AM
I think Emig racing does triple trees for the USD conversion,can't remember the web site a search will get it.
Here we go www.emigracing.com and go down the left side till it reads xr/crf fork conversion or something like that.
  • Mudshark
Posted March 05, 2006 - 07:18 AM
The answer to world tension! very cool. Thanks for the link. :thumbsup:
  • weskc35k
Posted March 05, 2006 - 04:04 PM
Mate i found it through someone elses post so "SHARE THE WEALTH"
  • asf
Posted November 06, 2007 - 09:05 AM
Any info on what I can do for steering stops on a XR600r which should be identical to the XR650L. Thanks!
  • Hot  35 replies
  • 3 replies
Honda XR650L 2017
  • 0 reviews
Honda XR650L 2016
  • 0 reviews
  • 22 replies
