She doesn't like to start.....
6 replies to this topic
  • nothingleft
Posted January 04, 2006 - 09:52 AM
I have the 2006 WR450 with the stock jets in it as listed here:
Main Jet = 165
Pilot Jet = 45
Pilot Air Jet = 80
Starter Jet = 65
Leak Jet = 50
I went for a ride this past weekend and she did not want to start. The bike had been in the back of the truck enduring the cold rain for 3 hours previous to the ride. I had to bump start it to get it going. So far, I have installed the TT AIS kit, PMB exhaust insert and removed the snorkel. It is still backfiring and popping like crazy. What should I do to help resolve the issues?
  • racejmac
Posted January 04, 2006 - 10:09 AM
make sure the ignition is not wet...
  • bg10459
Posted January 04, 2006 - 10:33 AM
Try adjusting the pilot screw, see if it has any effect.
What's your temp and elevation?
  • nothingleft
Posted January 04, 2006 - 11:23 AM
The temp was about 55F and the elevation was 1,000 ft.
  • bg10459
Posted January 04, 2006 - 12:59 PM
Sounds like you need to go bigger across the board. Start with a #70 starter jet and a #48 pilot jet. See how it works. You'll probably need a bigger main as well (maybe #170), and I'm not sure if you have an adjustable needle or not, but if so, try lowering the clip (raise the needle to richen) one groove at a time. As with all jetting changes, do one at a time so you can see what the effect is.
  • tmckeown
Posted January 04, 2006 - 01:02 PM
Hi,
Also check how much your fuel screw is open.
Timo Mc
  • Clifton
Posted January 04, 2006 - 04:55 PM
Main Jet = 165
Pilot Jet = 45
Pilot Air Jet = 80
Starter Jet = 65
Leak Jet = 50
I bought the JD Jet Kit and installed the170 main jet with the blue needle in the #5 position and my zip-ty fuel screw is 1 3/4 turns out. Bike starts perfect NOW (didn't when I bought it) and all the popping and backfiring is gone! Last weekend I was at about the same elevation at a couple of degrees warmer.
