YZ vs. WR
12 replies to this topic
  • harjp1959
Posted January 02, 2006 - 09:49 PM
Don't tell the DRZ guys this, but....
I've been looking for a used WR for desert riding and want to start doing enduros (someone has to finish last!) I've been looking at WRs because the YZ is an mx bike.
But tonight, I came across an ad for a '00 YZ426 for $2900.
What would I lose/gain going with a YZ vs. a WR, and vice versa.
  • Matty05
Posted January 02, 2006 - 09:53 PM
what model WR have you been looking at?
  • Bamster
Posted January 02, 2006 - 09:58 PM
So Hairlip, your getting rid of the gay DRZ?
The older WR's are easier to YZ then to WR the older YZ's.
In your area you would rater the WR's wider ratio tranny.
  • harjp1959
Posted January 02, 2006 - 10:17 PM
Older ones. 02, 03.
  • Matty05
Posted January 02, 2006 - 10:25 PM
What bamster said! Would be more effort offroading a YZ then tidying up a WR.
Good luck on your enduro's, remember you won't be last if you stick to yamaha!
Other bikes tend to break down! :applause:
  • Flaminchiten1967
Posted January 02, 2006 - 10:30 PM
a YZ with headlight and a little flywheel wieght will do you well I think.
  • StreetbikePimp
Posted January 02, 2006 - 10:34 PM
Put a Reckluse in that YZ and proper gearing, 14/52, and you're good to go. :applause: (not counting skidplate, rad protection, bark busters...etc.)
Depending on how much you weigh, the heavier springs of the YZ might even be good for your size, considering that the stock springs are usually set up for a 170 pound guy.
  • JSanfilippo
Posted January 03, 2006 - 12:16 AM
So you are finally getting a real bike huh?
Get the WR because its going to cost you an arm and a leg to get the YZ to make the tractable power you need in the woods. Those things (pre 03) are freakin savages
Unfortunately Im about 2 years from buying a real bike :applause:
  • moach1
Posted January 07, 2006 - 11:26 AM
yz only has 4 gears. get a wr.
  • xr_man
Posted January 07, 2006 - 12:55 PM
He said he was looking at 02 / 03 bikes so
should all be 5 speed
  • moach1
Posted January 07, 2006 - 01:09 PM
my bad. still get the wr
  • Beejay
Posted January 07, 2006 - 02:13 PM
Get the WR
  • Stinson
Posted January 07, 2006 - 07:53 PM
Im sure you can find a WR in that range if you look around a bit. I let my 03 WR go for 3k. Cya Stinson
